DP touches Fan...how bad is this?
Old Aug 5, 2004 | 08:51 PM
B18bEK's Avatar
Default DP touches Fan...how bad is this?
As you guys can see...its touching the fan. I know its gonna melt the plastic..but is there anythign serious that I should worry about prior to buying a slim fan?
Khoi
Old Aug 5, 2004 | 08:55 PM
b16sedan's Avatar
Default Re: DP touches Fan...how bad is this? (B18bEK)
Ever heard that 80's rock song "IT'S THE FINAL COUNTDOWN!" and then it busts in with some synthesizer? Replace count with melt. Gonna melt the whole motor housing down and kill your fan, most likely.
Old Aug 5, 2004 | 08:58 PM
fipracing_com's Avatar
Wrap your DP with thermo wrap, this will help.
http://www.thermotec.com/produ....html
Do yourself a favor and get a FAL fan, pulls much more air and lessens the chance of your car overheating.
Old Aug 5, 2004 | 09:11 PM
m R g S r's Avatar
You need a pusher fan on that setup. The housing is gonna melt and then cause the fan to stop working, and then the car will overheat. I'm sure you know this already . . . Alsom you might as well wrap the DP because it is kinda close to the radiator.
Old Aug 5, 2004 | 09:28 PM
B18bEK's Avatar
Default Re: DP touches Fan...how bad is this? (m R g S r)
could cutting the section of plastic that touches the dp help? Worst comes to worst..could driving for 30min be fine?
Khoi
Old Aug 5, 2004 | 09:38 PM
G3NR8's Avatar
Default Re: DP touches Fan...how bad is this? (b16coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe &raquo;</TD></TR><TR><TD CLASS="quote">Ever heard that 80's rock song "IT'S THE FINAL COUNTDOWN!" and then it busts in with some synthesizer? Replace count with melt. Gonna melt the whole motor housing down and kill your fan, most likely.</TD></TR></TABLE>
Hahahaaa
Old Aug 5, 2004 | 10:37 PM
gritsak's Avatar
Default Re: DP touches Fan...how bad is this? (G3NR8)
if you cant afford a slim fan then i would cut the section so it doesnt have direct contact with the DP then wrap that area of the DP good with some header wrap..then it should be fine
or just wrap the **** outta it and dont cut the shroud and see if it gets hot enough to melt it..either or
Old Aug 6, 2004 | 12:06 AM
B18bEK's Avatar
stop being so paranoid and freakin drive that ****.
Old Aug 6, 2004 | 12:57 AM
BoostedJeff's Avatar
Default Re: (B18bEK)
lol
Old Aug 6, 2004 | 05:32 AM
Dr Pooface's Avatar
Default Re: (JDMHatch4Me)
My wastegate dump ran in the same location. After two weeks the whole siade of the fan shroud had melted, and the fan was hitting the melted pieces when it ran. Sounded ghetto, looked ghetto, smelt ghetto.
Wrapped the tube with heat wrap, problem solved.
Old Aug 6, 2004 | 06:22 AM
DaX's Avatar
DaX
Loved
Community Favorite
Slim fan from B18bturbo was $60 shipped...zip tied it to the front of my radiator...plenty of room to play with.
Old Aug 8, 2004 | 09:23 PM
espanol's Avatar
i see you got the ole downpipe touching the radiaor fan special.
Old Aug 8, 2004 | 10:54 PM
Ri5e's Avatar
LOL. Just cut the damn thing already!
jonesdesign
Jun 18, 2009 07:18 PM
eric416
Apr 14, 2006 12:16 PM
kyle h.
Welding / Fabrication
Jun 22, 2005 07:18 PM
keebler65
Mar 18, 2002 02:35 PM
ithrowpoop
Mar 6, 2002 06:19 PM
