Rear rotors, what to get?
Old Aug 5, 2004 | 07:32 PM
Liquidgsr's Avatar
Default Rear rotors, what to get?
I have brembo cross drilled slotted front ones, I need new rear rotors, what kind should i get?
Old Aug 5, 2004 | 07:36 PM
Jeff R's Avatar
New User
Default Re: Rear rotors, what to get? (Liquidgsr)
oem style from autozone will do just fine.
jeff
Old Aug 5, 2004 | 08:09 PM
timmy8151's Avatar
Default Re: Rear rotors, what to get? (Jeff R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff R &raquo;</TD></TR><TR><TD CLASS="quote">oem style from autozone will do just fine.
jeff</TD></TR></TABLE>
Yeah, no need to spend a lot of $$ on rear rotors. Just note though, that Autozone stores don't carry the rears and are a special order item. However, you can order them online for about $17 each.
Old Aug 5, 2004 | 09:06 PM
IVI's Avatar
IVI
Default Re: Rear rotors, what to get? (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, no need to spend a lot of $$ on rear rotors. Just note though, that Autozone stores don't carry the rears and are a special order item. However, you can order them online for about $17 each.</TD></TR></TABLE>
the front is really what gives you the stopping power of the car.
why dont you see if you can get the rear rotors cut instead of buying new ones.
Old Aug 5, 2004 | 10:04 PM
patmcd's Avatar
Default Re: Rear rotors, what to get? (IVI)
Either get your current ones resurfaced or get some autozone blanks.
Old Aug 5, 2004 | 10:31 PM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquidgsr &raquo;</TD></TR><TR><TD CLASS="quote">I have brembo cross drilled slotted front ones, I need new rear rotors, what kind should i get?</TD></TR></TABLE>
Get OEM ones or Autozone blanks as people have said. Your fronts are basically OEM, no extra stopping power with what you have. No need to upgrade your fronts to anything else.
When upgrade the caliper and rotor assembly as a whole, then you are upgrading your stopping power. Note that on a road car like ours, cross drilled/slotted does nothing really. Just looks "cool."
Old Aug 5, 2004 | 10:47 PM
gser67's Avatar
Default Re: Rear rotors, what to get? (shamoo)
yeah just get some blanks...if you really want to help your stopping power i recommend axxis ultimate brake pads which i use with my cross drilled and slotted rotors...it slows my roll
Old Aug 6, 2004 | 01:25 AM
dave22's Avatar
You can get Brembo blanks for lile $22. I got mine at groupbuycenter.com
Old Aug 6, 2004 | 01:30 AM
Cliffjumper2's Avatar
brembo blanks oem replacement
here are a couple threads for you to look at including a HT sponsor who sell the brembo blanks (Import RP)
https://honda-tech.com/zerothread?id=935749
https://honda-tech.com/zerothread?id=831188
Old Aug 6, 2004 | 04:04 PM
StopChek's Avatar
get them from C-rotors 714 608 0818
good deal on brembro drilled/slotted rotors and Pbr pads
Old Aug 6, 2004 | 09:16 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Rear rotors, what to get? (patmcd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patmcd &raquo;</TD></TR><TR><TD CLASS="quote">Either get your current ones resurfaced or get some autozone blanks.</TD></TR></TABLE>
I wouldn't even bother trying to get old ones resurfaced. I went down to my local AutoZone and they had rear rotors for my car in stock for $17 each + tax, no shipping charges and no waiting to get them. Only 2 AutoZone locations in the whole city still resurface rotors so it was very worth it to me to just buy new ones rather than drive 60-80+ miles round trip, or twice that if I would have had to drop them off and pick them up later.
Old Aug 6, 2004 | 09:30 PM
P1mpSlap's Avatar
autozone's on cobalt GT pads
Old Aug 9, 2004 | 10:01 PM
Sack Master's Avatar
Default Re: (gotmilk80)
I would say get the same ones for the back. That way it matches. Alot of people will say how pointless it is do that. 80% of the time it's pointless to do anything to the front also.
Old Aug 10, 2004 | 04:13 AM
someday's Avatar
Default Re: (Sack Master)
i used the rear rotors off of a ep(the new si) they are the same size as the itr rears and already 4lug used the rotor and caliper works just fine, have older prelude vtec rotors on the front with accord wagon calipers, braking is now a night and day difference.
Bbasso
Dec 6, 2009 11:19 AM
Azxster
14
Oct 11, 2007 10:07 PM
HBADGE
10
Oct 13, 2006 01:07 AM
triple
May 17, 2006 10:23 PM
GiFF
Feb 13, 2002 09:21 PM
