Are all map sensors created equal?
Old Aug 5, 2004 | 07:00 PM
quik sol's Avatar
Default Are all map sensors created equal?
Alright I need a new map sensor and I was going to look around the parts houses but are they engine specific or obd specific?
1994 del sol VTEC B16a3
Old Aug 5, 2004 | 08:02 PM
turbohondask's Avatar
Default Re: Are all map sensors created equal? (quik sol)
they are all the same from 88-on
to have a similar one to yours get one from a 92-95 civic or 94-01 integra
Old Aug 5, 2004 | 08:41 PM
spaceman's Avatar
what does the map sensor do again and are they a wear item(do they need replacemant after a certain amount of time)?
Old Aug 6, 2004 | 07:41 PM
Default Re: Are all map sensors created equal? (spaceman)
measue the absoulte pressure going pass the throttle body, and almost everything is a wear item, but you should only change it if there is a code.
Old Aug 6, 2004 | 10:10 PM
spaceman's Avatar
Default Re: Are all map sensors created equal? (turbohondask)
good to know thanks dood
mrspeedy69
Apr 25, 2010 02:55 PM
robbys89
Dec 22, 2009 09:31 AM
4dooritr
Feb 24, 2006 02:59 PM
CivicHB_92
Jan 22, 2003 11:54 AM
B18C-RnVA
Aug 18, 2002 03:01 PM
