ef9 w/ itr suspension???
Old Aug 5, 2004 | 05:16 PM
chwy_thoj's Avatar
Default ef9 w/ itr suspension???
eh guys.. i'm an ef9 owner obviously and i had a few questions for you guys out there:
how simple is it to do a 98+ itr suspension/5-lug w/ brakes for ef9?
what parts are needed? entire setup or just select parts?
once installed, do i have to use itr sway bars? what sway bars should be used?
this is the most important question...
if it is possible to do an itr setup swap onto an ef9.... is possible to use the sway bars w/out the itr suspension??
I want to know if the itr sway bars, front and rear, can easily be fitted onto the ef9 chassis.
if this topic has been covered... please give me links.. i have yet to find the topic.
thanks for looking.. = ~)
Old Aug 5, 2004 | 05:24 PM
chwy_thoj's Avatar
anyone know anything about this topic..???
B
U
M
P
please... :smiles:
Old Aug 5, 2004 | 05:29 PM
chwy_thoj's Avatar
post your opinions.. please.. !! :thumpup: ..
anyone know anything about putting itr sway bars on civic??? ef9???
Old Aug 5, 2004 | 06:28 PM
UltimX's Avatar
Default Re: (chwy_thoj)
your going to need the hubs/knuckels and axles i believe. Sway bars will fit but are hard because of the bushing are different sizes. It should be a bolt on.
Old Aug 5, 2004 | 06:42 PM
chwy_thoj's Avatar
thanks a lot buddy.. so for the front ones.. what i have to do it drill new holes for the bushing mounts.. and have a nut placed on the top side of that crossbar of the chassis.. and also same as the rear for the bushing mounts such as when people do this swap.. itr sway bar onto their dc2 integras???
i remember helping a friend out with this project.
correct??
Old Aug 5, 2004 | 07:04 PM
UltimX's Avatar
I'm not to sure about that. I know u need to replace the bushing that goes through the sway bar for a bigger one. I'm not to sure about the end links.
fireblaze2k1
Jul 21, 2009 11:44 AM
nw dc two
Jan 7, 2007 01:59 PM
rough_draft
19
Jul 9, 2004 01:39 PM
StreetRacnGsR
10
May 21, 2003 06:15 PM
PhucNguyen57
Feb 21, 2003 05:54 PM
