Uneven Camber Question
Old Aug 5, 2004 | 04:31 PM
jdmfrontin's Avatar
Default Uneven Camber Question
i have a 95 integra with SPC camber kits. when i installed them on my car, adjusted all the way positive, and got an alignment right after. when i got my alignment done, the dude adjusted everything to be in spec but my camber on my drivers side is -1.1 degrees, while my passenger side is -1.5 degrees. since i put the camber kit in, when i gas my car it pulls to the left, and the steering wheel shifts a bit, and i get crazy bad treadwear. i was wondering if the reason why it pulls is because of the uneven camber, and if it is normal for camber kits to adjust unevenly. thanks for your help
Old Aug 5, 2004 | 05:52 PM
IVI's Avatar
IVI
Default Re: Uneven Camber Question (jdmfrontin)
camber should always be equal on both sides.
yes that can be a possibilty of why your car pulls.
how is the toe adjusted? proper toe settings should give you decent treadwear with a dropped car.
they should adjust evenly if your car is dropped properly.
TegGsr4dr
Jul 10, 2007 09:35 AM
Boost2NA
Nov 13, 2004 03:10 PM
Jeff99Base
Oct 26, 2004 04:49 AM
AcCO12D95
Jun 12, 2004 10:48 AM
jdmrealm
Nov 28, 2001 11:29 PM
