where to wire a tach in a cx?
Old Aug 5, 2004 | 02:50 PM
egreenmachine's Avatar
Default where to wire a tach in a cx?
in cx s there are no tachs, when i install one, how do you install the wiring? and what do you plug in where?
Old Aug 5, 2004 | 03:08 PM
kaoss_11's Avatar
B A N N E D
Default Re: where to wire a tach in a cx? (csxtasy)
Aftermarket? Need more details.
Old Aug 5, 2004 | 03:09 PM
BauleyCivic's Avatar
Risky Business
Default Re: where to wire a tach in a cx? (kaoss_11)
You can get a cluster from a 92-95 civic VX/LX/EX/Si and use that instead. Its just plug and play, no wiring needed y0!
Old Aug 5, 2004 | 03:12 PM
Slopoke's Avatar
Default Re: where to wire a tach in a cx? (BauleyCivic)
If you're wiring in an aftermarket tach, tap into the blue wire that sits in the corner by your driverside shock tower.
Its a single blue wire, usually taped up and the connector is in a little rubber cover.
Old Aug 5, 2004 | 04:04 PM
a1320honda's Avatar
Default Re: where to wire a tach in a cx? (Slopoke)
or a better way to do it so you dont have to run a wire through the firewall is tap the blue wire behind the gauge cluster. it makes for a cleaner engine bay if you dont have random wires in there. or yes there is the ex,si cluster which is direct plug and play.
Old Aug 5, 2004 | 04:37 PM
dpetro1's Avatar
Default Re: where to wire a tach in a cx? (a1320honda)
do u guys know if the jdm cluster is plug and play for the cx? will the tach work?
Old Aug 6, 2004 | 07:53 AM
alright, thanx for all the info, i might just do the ex cluster for the cleaner look.
Old Aug 6, 2004 | 09:16 AM
bcampbell's Avatar
Default Re: where to wire a tach in a cx? (csxcx)
I am glad you asked this cause I was wanting to know the samething. I am kind of a newby at working on cars.
Old Aug 17, 2004 | 11:19 AM
i found a blue wire on my shock tower that goes into some plastic thing thats i think is the right wire, but to i pull the wire out, or plug the tach wire into the other side? is this even the right wire?
Old Aug 17, 2004 | 12:14 PM
Another Drew's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">You can get a cluster from a 92-95 civic VX/LX/EX/Si and use that instead. Its just plug and play, no wiring needed y0!</TD></TR></TABLE>
The hard part is finding one I can't seem to fine one anywhere.
Old Aug 17, 2004 | 12:27 PM
Chicano's Avatar
Default Re: where to wire a tach in a cx? (Another Drew)
http://www.ebay.com has many, search for civic cluster
Old Aug 17, 2004 | 01:50 PM
JDM Like Whoa's Avatar
On my tach, I have a red, black, white, and green wire.
I know the red is power and black is ground but where do I put the white and green wires?
Old Aug 17, 2004 | 02:00 PM
a1320honda's Avatar
Default Re: (ImportRacr05)
okthe white wire is the illumination, you want that to come on when you turn on the headlights. the green is the signal wire. if you look at the wires behind the gauge cluster, you should find a blue wire, just tap into that.
Old Aug 17, 2004 | 02:04 PM
Do I run the red wire to a fuse up front? Thats what we did on my brothers car.
darkblackH2B
14
Feb 3, 2009 03:31 AM
89dohcEF
Sep 7, 2005 10:44 PM
opiumdaze
Aug 10, 2005 01:25 PM
joecivic93
Jan 6, 2004 10:07 PM
Freelance-GSR
Dec 11, 2002 01:18 AM
