Big big fuel troubles... HELP ME!!!
99 Civic Si, b16, uberdata, 450 DSM injectors.
I was driving this morning, car started acting up...not wanting to move at all, but for some reason, stayed pretty much in boost whenever I even touched the gas pedal. I'm getting alot of backfires, sounds horrible (like running on 3 cyl horrible). Plugs are fouled bigtime after just a short 15 mile drive. Burned like 1/4 tank of gas. Compression test revealed 220,220,200,220 psi. So, that's definately not the issue. It's like my injectors are in a solid dump mode. The car runs amazingly well in boost. Like better than is has ever run. Wideband is stuck on RICH, and it won't idle at all. NO CEL's. I don't think I've missed anything here.
When I plug the EFI fuse back in, my fuel pressure jumps up to 45psi, but it sounds like something is spraying. I unplugged each injector, still the same noise, just can't locate it. Sounds like it's coming from around the fuel rail area somewhere.
Edit...the injectors are not stuck open...Just checked that.
Modified by 99blusi at 1:05 AM 8/6/2004
Up because I need my freaking car running again by WEDNESDAY!!! I'm stuck driving my winter beater...and damn is it embarrassing.
B_Swapped93
Mar 25, 2013 08:02 PM
therealPROJEKTEG
Oct 25, 2005 02:19 AM
