Difference between 1997 and 2001 ITR rear calipers?
part numbers are different because honda went with a different manufacturer for the rubber piston seals and slide boots, but other than that... no difference in fitment. same part number for pads and rotors, etc.
Beware!
There is a difference in the way the rear calipers seem to bolt up to the hub/control arm.
I remember sgT had a problem fitting a non-97 rear caliper to his car.
To be on the safe side get the right caliper.
Yup, that's another one of the changes...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 »</TD></TR><TR><TD CLASS="quote">If I recall correctly, the bleeder screw is a different size on my 97 than newer Rs.</TD></TR></TABLE>
Bringing this back from the dead.....on my 97, my bleeder screw is 11mm. Such a odd ball size if you ask me. So nothing else will work for a 97 other than the direct replacement? Can anyone confirm this?
the mount place appeared to be different...meaning where the caliper bolts to the bracket..I just went throught this with my R.....the 97 is WAY more expensive and not offered as a reman. so its over 300 bucks for the 97 and bout 100 bucks for a reman 98 spec.
Modified by Madspeed at 9:25 PM 4/25/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petah »</TD></TR><TR><TD CLASS="quote">
Bringing this back from the dead.....on my 97, my bleeder screw is 11mm. Such a odd ball size if you ask me. So nothing else will work for a 97 other than the direct replacement? Can anyone confirm this? </TD></TR></TABLE>
Victor Perri has had to fool with this a few times. He has an early 1997 (#312). Look for him on aim as "siracer" and he'll tell you what he knows about it. He collects information.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Madspeed »</TD></TR><TR><TD CLASS="quote">the mount place appeared to be different...meaning where the claliper bolts to the bracket..I just went throught this with my R.....the 97 is WAY more expensive and not offered as a reman. so its over 300 bucks for the 97 and bout 100 bucks for a reman 98 spec.
That sucks. I have some autozone calipers on the rear of my 97 and was planning on doing some remaned calipers all around this summer...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petah »</TD></TR><TR><TD CLASS="quote">So as long as you get a 98+ caliper with bracket, you are set as i assume the trailing arm/hub is the same throughout the years.</TD></TR></TABLE>
If this is true then its not so bad anyone else confirm this?
</TD></TR></TABLE>That sucks. I have some autozone calipers on the rear of my 97 and was planning on doing some remaned calipers all around this summer...
For the $, I'd go with a rear caliper setup from fastbrakes using wilwood components or something.....
</TD></TR></TABLE>For the $, I'd go with a rear caliper setup from fastbrakes using wilwood components or something.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">
For the $, I'd go with a rear caliper setup from fastbrakes using wilwood components or something..... </TD></TR></TABLE>
But for those who want OEM, espescially if theres no front brake upgrade being done?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES »</TD></TR><TR><TD CLASS="quote">
But for those who want OEM, espescially if theres no front brake upgrade being done? </TD></TR></TABLE>
Same pads - just more pistons and no sliding caliper design.
They would also shed a bit of weight. But the main thing is how much easier it'd be to change pads.
But if we can get some 98+ w/ bracket and bolt it up to our 97s, we will be laughing. Question is will that solve the problem.
But if we can get some 98+ w/ bracket and bolt it up to our 97s, we will be laughing. Question is will that solve the problem.</TD></TR></TABLE>
Fine. I'll upgrade my rear calipers and you can have mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">Fine. I'll upgrade my rear calipers and you can have mine.
I am always up for FREE or CHEEEEEEAP parts!
</TD></TR></TABLE>I am always up for FREE or CHEEEEEEAP parts!
