Speedo/Tach/Temp/Dash Clock Not Working
Old Aug 5, 2004 | 09:56 AM
NickGSR95's Avatar
Default Speedo/Tach/Temp/Dash Clock Not Working
When I got in my car this morning none of this was working -
RPM Gauge (Tachometer)
Speedometer
Fuel Gauge
Oil Light
Dash Clock
I checked all the fuses and I couldn't find any blown.. or any even related to these things. The car still hits vtec.. drives normal etc. Just this doesn't work.
Anyone know the problem?
TIA
-Nick
Old Aug 5, 2004 | 03:00 PM
integlude's Avatar
Default Re: Speedo/Tach/Temp/Dash Clock Not Working (NickGSR95)
dude i have the exact same problem let me know what u find out
Old Aug 5, 2004 | 03:07 PM
B20 Twin Cam DC2's Avatar
Default Re: Speedo/Tach/Temp/Dash Clock Not Working (integlude)
have you taken the gauge cluster out of its housing?
Old Aug 5, 2004 | 03:10 PM
integlude's Avatar
Default Re: Speedo/Tach/Temp/Dash Clock Not Working (B20 Twin Cam DC2)
no i havent but i dont understand why the clock wouldnt be working either
Old Aug 5, 2004 | 03:13 PM
****, then its definately electrical, looks like you need to get a Voltmeter and test all wires to see which one isn't giving off current, (long process) good luck!,
Old Aug 5, 2004 | 03:26 PM
IVI's Avatar
IVI
gotta be a fuse or a shorted wire.
Old Aug 5, 2004 | 06:11 PM
tony4311's Avatar
Default Re: Speedo/Tach/Temp/Dash Clock Not Working (IVI)
just checking but you checked both fuse boxes right?
Old Aug 6, 2004 | 01:31 AM
slomob18b's Avatar
Yup check both fuse boxes man. The one in the engine and the one under your steering column to the left. The one under the steering column has alotta small ones so it may be a while unless you have a Helms or something. Last time my cluster/dash lights weren't working. Found a bad fuse in the box under the steering column. Just replaced it and it was all good.
Old Aug 6, 2004 | 10:34 PM
so simple's Avatar
you sure you checked all the fuses? i had the same problem before but i didnt check every fuse, it turned out to be the back up fuse or something like that
Old Aug 8, 2004 | 02:27 PM
integlude's Avatar
Default Re: Speedo/Tach/Temp/Dash Clock Not Working (simpleaznx)
now my car is blowing the cluster fuse i checked over every fuse in the car
Old Aug 13, 2004 | 07:55 PM
NickGSR95's Avatar
Yep, you guys were right, it was the back up light fuse.. strange. TY
Old Aug 14, 2004 | 08:34 AM
integlude's Avatar
which back up fuse was it
andertom
Aug 3, 2008 05:24 PM
Blue00Si
Oct 15, 2007 03:28 PM
Augustin
Jul 2, 2007 04:51 PM
jdmhagengsr
Sep 24, 2006 09:30 AM
PhazedSI
Jun 7, 2004 03:14 PM
