attn PROSPEED header peeps
Old Aug 5, 2004 | 08:13 AM
es_squared's Avatar
Default attn header guru peeps, prospeed headrrr
k i just got miiine, but i need to knw a few things cuz the guys at the exhaust shop needed to know . 1. what kind of flange do i need? will a stock honda one work ? 2. will it replace the flexpipe? ? im a newbie . tried calling prospeed but they almost never pick up
also how long does it take to do ? cuz they said it would take 4 hours
Old Aug 5, 2004 | 08:26 AM
GaRn's Avatar
Default Re: attn header guru peeps, prospeed headrrr (es_squared)
It should replace the flex pipe, cant the exhaust ppl look at it when you take it in?
Old Aug 5, 2004 | 08:28 AM
es_squared's Avatar
Default Re: attn header guru peeps, prospeed headrrr (GaRn)
ya i took it in and the guy said that removing the flexpip is bad . but if its aight then its allll goood . now what about a gasket ?
Old Aug 5, 2004 | 11:04 AM
es_squared's Avatar
Old Aug 5, 2004 | 11:18 AM
Daboi630's Avatar
shouldnt the exhaust shop have some to sell? i used my old one... but i dont have a prospeed header.
98TypeSH's Avatar
what type of material is the header made of? mild steel or stainless?
If its made of mild, i would STRONLY recommend putting a new flexpipe in line after the header. If its stainless then you should have no problems. Stainless is an all around stronger material and isnt really prone to cracking at the welds like mild is on this specific header. I like the design, its bad ***.
Old Aug 5, 2004 | 11:36 AM
es_squared's Avatar
Default Re: attn header guru peeps, prospeed headrrr (98TypeSH)
yea i went to a fairly small shop and they didnt have any flanges..
but yea mines mild steel, so i guese i should get a new flexpipe you say .. tomorow ill go to midas and see what they say, hopefuly they will have everything i need.
but would a stock flange work with it ?
Old Aug 5, 2004 | 11:46 AM
98TypeSH's Avatar
if you have a stock cat, they are probably going to have to cut the flange off the cat and use that. The flange that bolts to the cat is a weird size and type, at least from my experience and what the muffler guys said.
Old Aug 5, 2004 | 12:07 PM
KTeller8's Avatar
i got some flanges/gasket if you need to buy some
but id keep flexpipe on it at all cost, with all the threads of cracking and breaking, its not worth it to lose 500 bucks cause your didnt want to do it right!
Old Aug 5, 2004 | 08:53 PM
es_squared's Avatar
Default Re: attn header guru peeps, prospeed headrrr (KTeller8)
ok thakns for the replys guys, ill tell you how everything goes tomorow
Old Aug 5, 2004 | 09:57 PM
Shakes's Avatar
space cadet
damnit mike, i forgot all about the flex pipe till now.
**ordering**
I got my 2.5" flange and gaskets from Mike (kteller.com) and everything went perfectly.
Old Aug 5, 2004 | 10:31 PM
es_squared's Avatar
Default Re: attn header guru peeps, prospeed headrrr (Shakes)
god ! i hope i dont have to notch the cross member
Old Aug 6, 2004 | 04:52 AM
iakona's Avatar
is it best to put the flex pipe before or after the cat for a custom exhaust system?
Old Aug 6, 2004 | 06:50 AM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by es_squared &raquo;</TD></TR><TR><TD CLASS="quote">god ! i hope i dont have to notch the cross member </TD></TR></TABLE>
4th gen right? from what others have said you will. 5th gen guys dont, but we had the fitment issues.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">is it best to put the flex pipe before or after the cat for a custom exhaust system?</TD></TR></TABLE>
Before IMHO, get it close to the header to take as much of the beating as possible rather then letting your exhaust or the header take it.
Old Aug 6, 2004 | 06:55 AM
98TypeSH's Avatar
My header we re-worked and now fits perfect turn around time for the fix was 1 day.
Old Aug 6, 2004 | 08:03 AM
es_squared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">
no your lying ! !
Old Aug 6, 2004 | 10:33 AM
bad-monkey's Avatar
to brian.
Old Aug 6, 2004 | 10:46 AM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">My header we re-worked and now fits perfect turn around time for the fix was 1 day. </TD></TR></TABLE>
cool that was fast, it helps your somewhat local too.. longer for the east coast guys. but glad to see that it went well
doug, its cool i got it going out to you (flex)
Old Aug 6, 2004 | 11:15 AM
es_squared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">
yea.. i live in canada so it would tka eme a while if i have to send it back
Old Aug 6, 2004 | 02:06 PM
Shakes's Avatar
space cadet
doug, its cool i got it going out to you (flex)</TD></TR></TABLE>
SWEET!!!! another flawless transaction!
thanks mike!
Old Aug 6, 2004 | 08:54 PM
es_squared's Avatar
SUCCESS ! the header fit without having to do any extra modifcations !
Old Aug 7, 2004 | 04:36 PM
es_squared's Avatar
anyone else that installed the header feel something rubbing against another? i think it may be the crossmember cuz its pretty much touchign the header
YoungKadafi
32
Jun 10, 2006 04:33 PM
Vtakkk
Feb 24, 2006 02:14 PM
egg_baLLa
Dec 28, 2005 10:48 AM
flamega
12
May 24, 2005 03:15 AM
prelude10
Jan 24, 2002 02:56 AM
