95 civic jdmd15b swapped in it..
Old Aug 4, 2004 | 11:43 PM
labatia's Avatar
Default 95 civic jdmd15b swapped in it..
ok guys
swapped a jdm d15b into the 95 civic eg sedan
everything was good
all of a sudden car wont start
keep cranking.. now it stoped cranking at all
im assuming..
1.battery on car
2.altenator..
3. starter
4. distrub
also when i keep cranking smoke was coming out of the ecu
so i stoped cranking it and left it
its been in the garage for a month now and i wanan get it fixed
i miss my baby
Old Aug 4, 2004 | 11:46 PM
Evil_Wizard's Avatar
Default Re: 95 civic jdmd15b swapped in it.. (labatia)
what harness did you use? Sounds like maybe you tried using the stock JDM harness and some of the wires were crossed and fried something. If not please give more of a detailed description.
Old Aug 4, 2004 | 11:47 PM
labatia's Avatar
Default Re: 95 civic jdmd15b swapped in it.. (Evil_Wizard)
used the stock d15b7 harness
to a p08 ecu
sorry forgot to mention that
Old Aug 4, 2004 | 11:50 PM
Is it the JDM harness?
Old Aug 4, 2004 | 11:52 PM
labatia's Avatar
no my car is an ex canadian i didnt switch the harness
people on here said its a waste of money and to just connect the vtec
Old Aug 4, 2004 | 11:53 PM
Hmmm may want to go back and make sure you did all the wiring correctly. Sounds like you have a power and ground wire wired up incorrectly. Other then that I dont know bro sorry.
Old Aug 4, 2004 | 11:59 PM
labatia's Avatar
thanks
what i was going to do was ground everything for now with other wire.. what wire do you all suggest to use? also should i go buy new alt, starter, dist?
i dont even know if its the relays or fuel pump
Old Aug 5, 2004 | 12:02 AM
I wouldnt buy anything until you figure out what is bad. Could just be wasting money. On the ground though I would probably use 8 or 10 gauge wire to ground everything.
Old Aug 5, 2004 | 12:03 AM
labatia's Avatar
so off to the audio store eh
Old Aug 5, 2004 | 09:20 PM
labatia's Avatar
sum1 has to know
Old Aug 5, 2004 | 11:41 PM
labatia's Avatar
pics of my main relay..
Old Aug 6, 2004 | 02:18 AM
Broken Gearbox's Avatar
is your CEL on?
Old Aug 6, 2004 | 02:26 AM
labatia's Avatar
Default Re: (2.2L)
yah it was before
but now i haev no battery in it i think its dead
and i just checked the fuse which looks dead too
so im gonna try and buy a new battery and a fuse
Old Aug 6, 2004 | 08:25 AM
labatia's Avatar
Default Re: (labatia)
ttt
Old Aug 6, 2004 | 04:07 PM
labatia's Avatar
bump
Old Aug 6, 2004 | 04:17 PM
Street Ghost's Avatar
Did you forget to connect the grounds?
Old Aug 6, 2004 | 04:18 PM
ej1 pilot's Avatar
why did you have to wire vtec if you had an ex? was there a point in swapping basically the same motor into the car? im assuming it has high miles or something....sorry just wondering
Modified by Art In Motion at 8:45 PM 8/6/2004
Old Aug 6, 2004 | 06:37 PM
labatia's Avatar
Default Re: (Art In Motion)
d15b7 in ex
swapped to d15b
wtf
Old Aug 6, 2004 | 07:07 PM
civicboisi's Avatar
weird...i dont think ur main relays suppose to fry like that dude...something in your wiring is definatly wrong...just take the time to rerun everything...and the rewiring for VTEC is a good question...
Old Aug 7, 2004 | 03:53 PM
labatia's Avatar
Default Re: (civicboisi)
well today
infront of my work
sum guy with a honda i think older accord
his car wouldnt start
he called emergency assistent and the guy told me it is the ignition coil on the distrub.. he said no body changes them and just get new distribs
so maybe that could be it
Old Aug 9, 2004 | 04:04 PM
labatia's Avatar
ttt
Old Aug 9, 2004 | 06:24 PM
NineTwoSi's Avatar
that is one nasty *** lookin' main relay... the pics fuzzy so it's hard to tell, did it fry or is it corrosion?
Old Aug 9, 2004 | 10:43 PM
labatia's Avatar
Default Re: 95 civic jdmd15b swapped in it.. (I Am Jack)
looks fried and has a whole lot of corossion on it
acid was on it too
my hands were all numb after lol
Old Aug 9, 2004 | 10:49 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art In Motion &raquo;</TD></TR><TR><TD CLASS="quote">why did you have to wire vtec if you had an ex? was there a point in swapping basically the same motor into the car? im assuming it has high miles or something....sorry just wondering
Modified by Art In Motion at 8:45 PM 8/6/2004</TD></TR></TABLE>
he is from canada...so ex doesn't come with the d16z6.
Old Aug 11, 2004 | 02:05 AM
labatia's Avatar
Default Re: (SOHC_MShue)
wow im surprised no one can help
