Should I Save it or Sell it? My 88 Rex
Hey guys- whats up
I bought an 88 Honda CRX DX for like 450 from a guy in downtown chicago in the winter...and I love it as a driver- the main reason i got it was for a driver...but I knew that part of me just had to fix it up- Now that the time has come... I don't know whether I should save it or not...The rust is pretty bad all over the car- I need your help on decding on whether i should fix it or not
Both Rear Quarter Panels- All the way through from the bottom up- Lost original shape- Will need replacing-- On the driver side, rust is in the gas filler compartment
Rocker Panels Both sides- run along the door- rusted away- can't step on 'em or rust may fall!
Driver Door- Rust hole Bottom corner- [most likely fixable w/ a fiberglass patch]
Frame Rust- rust starting on rails
Small spots on the rest of the car fixable w/ patches or filler
Basically, If you've fixed it before- could you tell me how it went and how difficult it was and how to do it pretty much- Money is a large factor considering i spent 450 on the car- Umm..prolly a $500 spending limit?
I want it to look like a CRX should...but im also worried about the actual structural strength of it
The car only has 105k miles and runs like a dream...I could drive it into the ground if i wanted to- Is there hope for it?
Thanks a lot
Thanks a lot
Don't replacing panels usually run pretty high in the dollar department?
IMO, that car is shot. It'll probably cost you more to fix the car than picking up a better conditioned CRX would, unless you do all the work yourself. Maybe you should spend the 500 bucks on a CRX shell and transplant the motor over?
japrex
Nov 11, 2004 03:47 PM
I3ackfire
Feb 23, 2004 11:11 AM
