Engine rebuild update: Day One
Old Nov 28, 2001 | 09:14 PM
HX_Guy's Avatar
Default Engine rebuild update: Day One
First of all - this is REALLY time consuming!
I would of had a little more accomplished but I misplaced a lower main bearings! Ahh...still didnt find it! I hope someone local has it in stock or it will set me back hard.
I did get the pistons installed and checked the ring end gap as well as deck clearance.
The ring end gap was right around .014"-.015". Endyn suggests .012" - .13" but what can I do.
The deck clearance pissed me off! I was expecting a clearance of around .020" but mine is around .030" (.030"-.032"). That will make my compression 10.9:1 which is lower then what I want. I guess Ill ahve the head milled .020" to achieve 11.5:1.
I also plastigauged the main bearings. All were right around .015" - .016"
Specs are .0009" - "0017 with the service limit being .020" so I figure Im good with those.
So on tomorrow's agenda...I need to find a lower main bearing (black) and then I can do a final install of the crank and then move on to plastigauging the rod bearings...hopefully those will all be ok.
Old Nov 28, 2001 | 09:30 PM
Rory Breaker's Avatar
Default Re: Engine rebuild update: Day One (HX_Guy)
Youre going to be one busy dude...
I wish you the best of luck!!!!!!!!!!
Old Nov 28, 2001 | 09:32 PM
Tomakit's Avatar
Default Re: Engine rebuild update: Day One (newgsrdriver)
YEAH!!!!!
(btw, i've found a cheap source on b20b longblocks...so i might just be following in your footsteps, hehe)
Tom
Old Nov 28, 2001 | 09:52 PM
OneThirtyEight's Avatar
Default Re: Engine rebuild update: Day One (Tomakit)
Good Luck! I should have done the same with my LS engine
Old Nov 29, 2001 | 12:13 AM
B18C-RnVA's Avatar
New User
Default Re: Engine rebuild update: Day One (97blackteg)
thats hot, keep us updated and i hope you find your bearings.
Old Nov 29, 2001 | 06:50 AM
HX_Guy's Avatar
Default Re: Engine rebuild update: Day One (B18C-RnVA)
Woohoo! Happy days are here again!
I called up the local Honda dealer where I got all my parts from, and the missing bearing half is there! I guess they never put it in the box with the rest of them and somehow I mis-counted it.
Old Nov 29, 2001 | 08:31 AM
owen_the_soyboy's Avatar
dude, you RULE! thanks for th eupdates, yummy pics, and info. this is cool to hear it in the works.
Old Nov 29, 2001 | 08:37 AM
HX_Guy's Avatar
Default Re: Engine rebuild update: Day One (owen_the_soyboy)
My pleasure
Heh..I kinda feel like Truman in The Truman Show
Old Nov 29, 2001 | 05:51 PM
non-VTEC's Avatar
when you say the deck clearence is not what you expected it to be.........does that mean the pistons sit about .030 below the deck surface at TDC?
Old Nov 29, 2001 | 07:15 PM
360's Avatar
360
Default Re: Engine rebuild update: Day One (non-VTEC)
You working on it alone? Things like that are a lot easier with a friend, imo. Good luck with everything
willfly
Jun 4, 2013 05:10 AM
sackdz
Oct 26, 2006 08:10 PM
93sidelsolvtec
Aug 7, 2006 02:16 AM
importlegions
Oct 11, 2005 02:54 PM
dustin
May 11, 2002 06:49 PM
