Camber Kit..car walks like crazy and stering is loose..is this normal??
Old Nov 28, 2001 | 09:08 PM
jdmciviceg's Avatar
New User
Default Camber Kit..car walks like crazy and stering is loose..is this normal??
Hey guys. I put a Specialty Products camber kit on last night and my car is walking like crazy and the stering feels real loose. I have not had it aligned yet, but was wondering if it is because the kit I bought put too much correction in it (positive camber). I have it set to the lowest correction, 1.75 degrees of adjustment. I didn't want to get it aligned if it was still going to steer like it does now. I'd rather go through tires a little faster then feel like the car does not steer as well as it did before. Do you think the alignment will make it drive correctly or do you recommend just taking it off and leaving some negative camber in it? My car is dropped about 2-2.5" in the front.
Old Nov 28, 2001 | 09:57 PM
WykidEH's Avatar
Default Re: Camber Kit..car walks like crazy and stering is loose..is this normal?? (jdmciviceg)
Get a alignment!
Old Nov 28, 2001 | 10:18 PM
gsrvx's Avatar
New User
Default Re: Camber Kit..car walks like crazy and stering is loose..is this normal?? (WykidEG6)
Get a alignment!
I second that
Old Nov 28, 2001 | 10:34 PM
WykidEH's Avatar
Default Re: Camber Kit..car walks like crazy and stering is loose..is this normal?? (RK)
HAHAHAHA! LOL
Old Nov 28, 2001 | 10:36 PM
gsrvx's Avatar
New User
HAHAHAHA! LOL
What's so funny ???
Old Nov 28, 2001 | 10:39 PM
WykidEH's Avatar
I know the guy.
Old Nov 28, 2001 | 10:40 PM
gsrvx's Avatar
New User
Old Nov 29, 2001 | 02:52 AM
mps9506's Avatar
Get the alignment find out what your camber specs are. It's probably something other than your camber that is causing instability.
Old Nov 29, 2001 | 06:55 AM
Crazydave's Avatar
Default Re: Camber Kit..car walks like crazy and stering is loose..is this normal?? (mps9506)
your toe is probably way out of wack..
also check the caster....
if that is off that can also cause instablilit..
I know that with my camber kits if you flip over the plate that the ball joint is on you can put a butt load of caster and that will make straight line driving really interesting
Old Nov 29, 2001 | 09:04 AM
Honda318dx's Avatar
Default Re: Camber Kit..car walks like crazy and stering is loose..is this normal?? (Crazydave)
toe is off, set the camber even when the alighment is being done..
Old Nov 29, 2001 | 09:05 AM
Mike P.'s Avatar
25 Year Member
The toe is what's making it funny. Get an alignment (once again) and there's no reason it shouldn't track straight and true. Caster isn't going to affect straightline stability. More caster would make it feel a little more positive, anyways...
Old Nov 29, 2001 | 09:09 AM
Jeff_S's Avatar
Well, it's been said... but when you put on a camber kit in the rear, you usually introduce some toe-out. This makes the car feel exactly like you're describing. If you don't get an alignment quick... and I mean real quick, your tires will be gone within 2000 miles.
Old Nov 29, 2001 | 09:11 AM
jdmciviceg's Avatar
New User
Thanks for the advice guys. I got off my cheep *** and already took it to the alignment shop bright and early this morning before I checked the posts. Hopefully it will be all good then.
hatch96y7
Oct 13, 2007 09:27 AM
crx1009
Apr 5, 2006 09:57 AM
mikeunreal
Suspension & Brakes
10
Nov 20, 2005 07:26 PM
Trumpster
Suspension & Brakes
Feb 2, 2005 08:14 PM
Rhythm Racer
31
Jan 27, 2004 10:34 PM
