My first attempt at welding...and ABS progress pictures
Old Aug 4, 2004 | 09:19 PM
Jonathan_ED3's Avatar
Default My first attempt at welding...and ABS progress pictures
Went a LOT better than I expected actually.
Turned on the old Mig welder that my dad used professionally a few decades ago and just said what the heck. It actually worked...who would have guessed. I need to grind off some of the lower weld and re-do it because I couldn't get a very solid bead, but you get the idea.
I think I maybe didn't have the voltage hot enough or I had it grounded poorly? I got a great bead on the backside, so I don't know what the variable was.
This bracket is to hold my ABS actuator pump in place. I had to modify it to fit my EF because it comes from the DC chasis. It fits very good now! A little grinding, a TAD bit more welding and I'll paint this bad boy. Not bad!
If you compare the above to this picture you can see that the bracket was significantly altered. I had to do a bunch of cutting just to make it fit in the first place, but now it's an excellent fit.
Engine bay will be painted by the end of the week...at least primered. I spent half the day taking care of some rust that I had to grind all the way down to bare metal. Thankfully I'm using a high-build primer so with a little sanding the big dips from the grinder won't be visible.
The black you're seeing on the frame rail is just some spray-can primer I put on to keep the bare metal from rusting until the real primer/sealer goes on. You can see in the other pictures how bad the rust was...that was from battery acid that had dripped down the frame rail over the years I assume.
I'm going to stop typing now because I'm pretty sure only a few people will even care
Old Aug 4, 2004 | 09:27 PM
shaddr3's Avatar
Default Re: My first attempt at welding...and ABS progress pictures (Jonathan_EH)
Eligant!
Old Aug 4, 2004 | 10:00 PM
Synth124's Avatar
Cool, I wish my dad had an old welder doing nothing in the garage for me to use!
Old Aug 4, 2004 | 10:03 PM
Sobe_Death's Avatar
ABS huh? interesting. you have a link to where you first started the project?
Old Aug 4, 2004 | 10:09 PM
MonkeyMagic's Avatar
Default Re: My first attempt at welding...and ABS progress pictures (Synth124)
absotively fawking awesome
i can't wait to start on my project car... it'll be in the garage for years but it's so fun to play mechanic/engineer/fabricator/god
Old Aug 4, 2004 | 10:10 PM
Full Race A6's Avatar
Default Re: (Sobe_Death)
Welding is a skill that will always be needed, I really hope to grab the concept before Im 20
Old Aug 4, 2004 | 10:41 PM
ImportHatch's Avatar
Default Re: (Full Race A6)
I love welding. Get some more practice with it and you can make anything.
Yager-
Old Aug 4, 2004 | 11:51 PM
Engine bay sanded down...Notice I still have to do the driver side...notice how shiney the shock tower is compared to the passenger side?
I'll be primering the engine bay early Friday morning out in the driveway...neighbors will love it.
Old Aug 5, 2004 | 12:09 AM
rasta420's Avatar
Default Re: (Jonathan_EH)
did you use new custom brake lines or did you just modify stock ones? what knuckles/brakes are you using? ECU?
Old Aug 5, 2004 | 12:33 AM
Custom brake lines except the rear that come out of the firewall.
I took those out and reversed them...the one that used to be on top is now on bottom. This made them line up perfectly with the Integra valve that I mounted in the stock location on the shock tower. I had to drill one hole to do so, but I was able to use an OEM threaded hole also.
DA knuckles, 11" brake setup. Axles will have to be custom I'm sure; I'm converting to Hydro D series transmission as well.
ECU will be a P28 (probably)...still working on the wiring aspect. I don't have an Integra Helms yet, so it's not completely finalized.
Old Aug 5, 2004 | 06:16 AM
Driven's Avatar
oh oh oh....
WHY ABS in an ED chassis?
Old Aug 5, 2004 | 07:41 AM
4drEF's Avatar
Keyboard Humorist
Default Re: (Driven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">oh oh oh....
WHY ABS in an ED chassis? </TD></TR></TABLE>
didn't the EF (JDM) chassis come with it?
ABS in an ED has been done before
https://honda-tech.com/zerothread?id=458657
Old Aug 5, 2004 | 08:07 AM
Because I want to. Not everybody these days builds a car at the whim of fellow H-T'ers.
Additonally, I'm a broke and jobless college student out for the summer with nothing but time on my hands. so why not?
I've got a loaded LX sedan...by the time I'm completely done with the car, it's going to be close to the weight of an Integra; I'm not going to buy the argument about the car being too light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=458657</TD></TR></TABLE>
Yeah I know Ken has done the ABS before....I wasn't trying to say I'm the first. He is where I got the idea though.
I am doing this completely on my own though...I PMed Ken a few months ago just to see if his ABS works and to ask him some very basic questions, but everything on my actual install is from my own mind.
If you notice in his pictures he just retrofitted everything as best he could directly from the Integra. I thought about doing that, but it seemed like an even bigger PITA than starting over custom.
Old Aug 5, 2004 | 08:09 AM
EL Vap133's Avatar
Looks good man, keep us updated!
Old Aug 5, 2004 | 08:10 AM
4drEF's Avatar
Keyboard Humorist
My "done before" comment was directed toward driven.
Comes factory in some EF's
Has been added to ED's
Old Aug 5, 2004 | 08:35 AM
oh, I apologize. I thought you were directing it at me to lessen the neat factor
Old Aug 5, 2004 | 08:57 AM
CRX T-Si's Avatar
Very interesting, I wonder what kind of benifit you get with ABS in an EF.
When it's done please post some brake test comparisons, to see how shorter of a stopping distance you get with ABS in an EF.
Looks pretty good man.
Old Aug 5, 2004 | 09:24 AM
I'm not worried about a shorter stopping distance. In fact, I don't think ABS makes the car stop in a shoter distance; the goal, rather, is to prevent wheel lock up - particularly in slick situations.
Old Aug 5, 2004 | 09:32 AM
Driven's Avatar
Default Re: (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_EH &raquo;</TD></TR><TR><TD CLASS="quote">Because I want to. Not everybody these days builds a car at the whim of fellow H-T'ers.</TD></TR></TABLE>
Thank god, or we'd be surrounded with JDM bling bling cars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I've got a loaded LX sedan...by the time I'm completely done with the car, it's going to be close to the weight of an Integra; I'm not going to buy the argument about the car being too light.</TD></TR></TABLE>
my fault, i forgot about the sedans. I keep thinking there are only hatchs and CRXs that exist on this forum
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">Very interesting, I wonder what kind of benifit you get with ABS in an EF.</TD></TR></TABLE>
In a CRX or hatch. none.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">When it's done please post some brake test comparisons, to see how shorter of a stopping distance you get with ABS in an EF. </TD></TR></TABLE>
you wouldn't see shorter stopping distances at all.
ABS just prevents wheel lock...which can be modulated with your foot. it's a handicap type of device that allows people to slam their foot on the stop pedal as hard as they want...without having to worry about pumping the brakes or "applying" the brakes.
ABS is great for icy roads and such, due to it being far more difficult to modulate your brakes in those conditions.
Jonathan, how are going about the wheel sensor issue?
Old Aug 5, 2004 | 10:01 AM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">Jonathan, how are going about the wheel sensor issue? </TD></TR></TABLE>
Good question - I want to know what you're planning too!
Old Aug 5, 2004 | 10:42 AM
The only major issue left is the axle issue. I'm almost 100% sure they'll have to be custom, but that's nothing my local driveshaft shop cannot handle for me.
I modified the DC wheel sensor assmebly to mount on DA knuckles.
For the rear, I'm using the entire DC trailing arm with all the sensor/ABS ring etc already mounted. No trouble there.
Old Aug 5, 2004 | 11:16 AM
CRX T-Si's Avatar
So all that trouble for nothing then.........
Since you have time how about helping a fellow H-T member modifying a hood. I need on with a 2" raise cowl induction.
Old Aug 5, 2004 | 12:34 PM
b16_madman's Avatar
i guess you just had a mass of stuff lying around waiting for the summer to hit so you could start on this?
Old Aug 5, 2004 | 12:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">So all that trouble for nothing then.........</TD></TR></TABLE>
What do you mean? When it rains in TX it gets very slick...the ABS will be a huge improvement.
As far as the parts....I just happen to run across a GSR in the junkyard that had everything brake-related intact, I figured I'd never get a chance like that again so I just decided to pick it all up.
I was actually planning on doing everything NEXT summer after I got money for the engine, suspension etc but I ended up never getting a part-time job this summer so I said WTF, I'll just go ahead and start.
Old Aug 5, 2004 | 12:58 PM
CRX T-Si's Avatar
Your fogetting where I live, MIAMI.
It's being raining here for the last 2 weeks, some crazy **** I tell you.
I don't remember the last time the ABS kicked on when I was driving my Z3. When it kicks on you can feel it and as much as it rains here I have yet pushed it hard enough for it to turn on.
I always ABS was always extra weight, but hey what ever floats your boat.
Good luck on the install.
