need help asap PLEASE HELP
Old Aug 4, 2004 | 08:00 PM
upi95civic's Avatar
Default need help asap PLEASE HELP
I'm going to remove the motor from my car today to put a new clutch in and i can not get the pin out of the shift linkage its rounded out and can not punch it out is there any way i can fix it or get it out anyother way
Old Aug 4, 2004 | 08:06 PM
Redline130's Avatar
Default Re: need help asap PLEASE HELP (upi95civic)
You know you don't need to remove the motor to change the clutch right? Anyway, if you can't get it out with a punch from below, just unbolt the entire shift linkage from the car and drop it with the tranny. Then you can try and punch the pin out from the top of the linkage.
Old Aug 4, 2004 | 09:57 PM
Synth124's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by upi95civic &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to remove the motor from my car today to put a new clutch in and i can not get the pin out of the shift linkage its rounded out and can not punch it out is there any way i can fix it or get it out anyother way </TD></TR></TABLE>
Trust me YOU can get it out with a punch, you just need to find the Correct size! Go to autozone buy the Great Neck punch set, one the punches works perfect! It will come out easy as butter.
Old Aug 5, 2004 | 05:20 AM
upi95civic's Avatar
ttt
Old Aug 5, 2004 | 05:32 AM
Keebler's Avatar
Why did you bump this? You got 2 good responses for your problem, plus if you would have searched for bitch pin or transmission hinge pin or any combination thereof, you would have found even more answers.
Old Aug 5, 2004 | 05:49 AM
upi95civic's Avatar
Default Re: need help asap PLEASE HELP (Keebler)
well you bumbed it again by replying so why did you even say anything
Old Aug 5, 2004 | 06:08 AM
T--Rex's Avatar
Default Re: need help asap PLEASE HELP (Synth124)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synth124 &raquo;</TD></TR><TR><TD CLASS="quote">
Trust me YOU can get it out with a punch, you just need to find the Correct size! Go to autozone buy the Great Neck punch set, one the punches works perfect! It will come out easy as butter.</TD></TR></TABLE>
Old Aug 5, 2004 | 07:53 AM
Keebler's Avatar
To point out the fact to you that you received good information from these people.
As a guideline, when somene answers your question, you go with it
MikeY326
Dec 27, 2009 10:35 PM
Paluce
Mar 25, 2005 01:31 PM
ScootinIntegra
Apr 7, 2004 12:44 AM
GirlyGirlGSR
Oct 31, 2003 07:58 AM
kshymkiw
Dec 3, 2002 07:21 PM
