Exhausts
Old Aug 4, 2004 | 07:41 PM
lastpunkinline's Avatar
Default Exhausts
Im looking to buy a new exhaust since my greddy sp is falling apart on me. Does anyone have any advice as to the new exhaust i should buy? Some where in the range of 300-800$. thanks
Old Aug 4, 2004 | 07:49 PM
patdemps's Avatar
Default Re: Exhausts (lastpunkinline)
What kind of power are you looking at putting to the ground?
All motor or turbo?
Im assuming All Motor so i'd say go with 2.25"-2.5" mendral bent piping from an exhaust shop and then get a muffler, have them weld it and your golden. It'll cost you much less and you'll know your quality. While your at it you might aswell grab a Cat or a straight pipe with the extra money and slap that on at the same time.
If you want to spend $800 and get some good performance then go this route: JDM DC 4-1 header, straight pipe or carsound cat and a 2.25"-2.5" mendral bent exhaust/muffler and I think you could slap it all on for around 800 or so. Just search around your muffler shops in the area and get some quotes. You may even be able to land a Comptech header (i think there right around 500) and then do a straight pipe/exhaust and keep it around 800. Because mendral bent exhaust shouldn't run you more then 300 at a local exhaust shop.
This way here you have a header back setup instead of just an exhaust
f22b2ecstasy
Oct 6, 2007 11:37 PM
honda95civic
Welding / Fabrication
Jun 9, 2005 10:14 AM
xmr. robotox
Mar 2, 2005 02:30 PM
valentinecr
Nov 29, 2004 04:04 PM
bad93ex
12
Sep 26, 2002 05:27 AM
