Erratic temp gauge?
Old Aug 4, 2004 | 06:07 PM
Ti3d in's Avatar
Default Erratic temp gauge?
I was driving around today, and I notice my temp gauge moving around more than usual. At idle, the gauge would move up all the way to H, and when accelerating, it would move back down. I pulled over to the side of the road, and checked around. Motor didn't feel like it was too hot, and I didn't see any coolant leaks. Fans were on, but after idling for awhile they turned off which means everything is OK? Also, I turned on the heater all the way and cold air came out, which could mean I have no coolant in the system? Broken thermostat or ECT sensor? BTW I'm still running the stock radiator.
Old Aug 4, 2004 | 06:27 PM
SMC Integra's Avatar
Default Re: Erratic temp gauge? (Ti3d in)
run the car for a bit until the engine gets up to temperature and then grab your upper radiator hose to see if it is hot or cold. If it is cold or cool, then your thermostat is malfunctioning.
Old Aug 4, 2004 | 06:38 PM
Ti3d in's Avatar
Default Re: Erratic temp gauge? (SMC Integra)
NM I fixed it. I was running low on coolant...had a bunch of air in the system.
Tmich91
Dec 13, 2018 03:27 PM
Stevek414
Jan 9, 2015 01:36 AM
crxguy406
Apr 17, 2013 06:47 PM
TOO MUCH TORQUE
Jul 28, 2010 09:21 PM
`chrisb
Apr 25, 2008 07:52 PM
