Rear Main Seal Part #?
Old Aug 4, 2004 | 05:35 PM
90LSpimpin's Avatar
Default Rear Main Seal Part #?
Hey all. I'm going to be chaning my clutch and figured I should do change the rear main seal at the same time. Could anyone tell me what the part number is for it?
I think its either #24 on this link: http://www.hondaautomotivepart...L+PAN
or its #10 on this one http://www.hondaautomotivepart...USING
Could anyone clarify this for me? Thanks in advance.
Also is there anything else I should hit while i have the tranny off? Thanks.
Old Aug 4, 2004 | 05:46 PM
BlueShadow's Avatar
Default Re: Rear Main Seal Part #? (WeaponRex86)
#24 is Honda & Acura p/n 91214-PH1-004 "OIL SEAL (80X100X10) (ARAI)"
#10 is Honda p/n 91206-PL3-A01 "OIL SEAL (35X62X8)"
# 24 sounds like the one you need though, because #10 is the transmission oil seal fpr the passenger side axle. EDIT: if you have the tranny off I would also change out the throwout bearing and throwout bearing return spring. If you are resurfacing the flywheel, you should also replace the pilot bearing.
Honda p/n 22810-PL3-005 THROWOUT BEARING
Honda & Acura p/n 22851-PB6-910 SPRING, RELEASE ARM
Honda & Acura p/n 91006-634-008 BEARING, CLUTCH PILOT (TOYO)
Old Aug 14, 2004 | 06:09 PM
94gsr_vtc's Avatar
i tink it is pat numba 1 twunti foor
oh your hatch is primer foo
CPR
Nov 19, 2010 07:09 AM
92hondalude
Jan 12, 2005 01:59 PM
BigIslandBoi
Sep 19, 2003 12:16 AM
overdose
Apr 23, 2003 10:57 AM
CivicTuneR95
Jan 13, 2003 10:17 AM
