How can I identify a del sol dual core rad?
I just bought what is supposed to be an aftermarket del sol dual core rad, but I'm not sure how to tell if its really a dual core rad.
How thick should it be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by model x »</TD></TR><TR><TD CLASS="quote">I just bought what is supposed to be an aftermarket del sol dual core rad, but I'm not sure how to tell if its really a dual core rad.
How thick should it be?</TD></TR></TABLE>
very very easy.
its twice as thick as your stock one. stock one is about 5/8" thick (core, not tanks). del sol vtec one is about 1-1/4" thick. very very noticeable; you don't need a measuring tape to tell the two apart!
todd
ps i have an all metal one, barely used, for sale. best offer!
very very easy.
todd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd Reid »</TD></TR><TR><TD CLASS="quote">
Will it fit a 95 Civic Ex Coupe (EJ1)? If so, how much? PM me.
here is a pic of one i was dissapointed in how thin it still was. deep down i hoped it would be like 2 inchs thick, i new it wouldn't but im also a wishfull thinker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moto27cm »</TD></TR><TR><TD CLASS="quote">That looks like a single core to me.</TD></TR></TABLE>
agreed
agreed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevel »</TD></TR><TR><TD CLASS="quote">
agreed</TD></TR></TABLE>
both of you are wrong, a single core civic rad is about as wide as a pencel you can fit two pencels in this things width.. hence its a DUAL core rad.
go look under the hood of a SOHC 92-95 civic, you will see
that looks the same as the one that I bought; 1" thick. But there'd only one row of holes inside. But its aluminum so I wonder if that would make up for not being dual core?
here is a picture of my del sol vtec radiator for sale. noticably thicker than the one you have. and its all metal, too:
http://www.we-todd-did-racing....D.jpg
thats definitely a del sol vtec rad!
good luck with your car!
todd
todd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">
Ugggh, I guess you haven't seen a del sol dual core before. go look under the hood of a SOHC 92-95 civic, you will see</TD></TR></TABLE>
Ok. I have a 95 SOHC and slammed_93_hatch's looks just like mine. I definitely have a stock single core. Todd Reid's is a dual core, slammed_93_hatch's is most definitely single core.
See pic. Stock single core SOHC out of my 95 hatch. Most definitely smaller than Todd Reid's dual core.
s
s
How many rows of passages are inside your rads?
The 78 civic rad I have now is actually a dual core rad, its about 2" thick. I'm worried it might be clogged though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">mine i have is twice as thick as the one my car came with but is not as thick as the ones shown</TD></TR></TABLE>
Hmmm, I guess I'm wrong then. Yours looks just like mine. The del sol dual cores I've seen all have been as thick as Todd Reid's.
s
s
Ditto. Todd Reid's is a dual core, while slammed's is a single core. I have seen plenty of single and dual core rads. I dont know what you had in there before, but the one you have in there now is a single core...bottom line.
Agreed.
It's real simple to tell... dual core should be as wide as the end tanks where as single core's are thinner then the end tanks.
BTW, I don't think all sohc civics had single core. When I did my swap I ordered a dual core del sol vtec radiator. When I got it, it was exactly like the one already in the civic. Since it was an EX with the 1.6 sohc vtec I gues it had a dual core to begin with. Either that or when the previous owner rear ended someone and it got fixed they just put in a dual core instead of a single??? I still replaced it though so I could have a fresh new radiator.
AS far as the pencil analogy... eek, 1 pencil is damn thin so I'm not sure what off the wall brand that was but eeek. But to use the pencil scale, a single core would probably be about 2 pencils and the dual core 4 pencils
Again a dual core should be as thick as the end tanks, if it is not then it is single core
Modified by h22avid at 12:15 PM 8/6/2004
Modified by h22avid at 12:20 PM 8/6/2004
DRKSol
30
Sep 24, 2006 05:59 PM
shorty0o29
May 14, 2004 06:30 AM
