g3 DIY Trunk Brace question.
Old Aug 4, 2004 | 12:42 PM
TrueUntilDeath.com's Avatar
Default g3 DIY Trunk Brace question.
which type of bar would be more effective in a diy trunk brace bar project? a square or round? this will be for a dc chasis. which one would be stronger againts flex?tia
Old Aug 4, 2004 | 04:17 PM
Circuit Star-29's Avatar
Default Re: g3 DIY Trunk Brace question. (GMR MM12)
Round.
Old Aug 4, 2004 | 05:35 PM
Default Re: g3 DIY Trunk Brace question. (nathan atwell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathan atwell &raquo;</TD></TR><TR><TD CLASS="quote">Round.</TD></TR></TABLE>
how so?
Old Aug 4, 2004 | 06:11 PM
Mediocre Generica's Avatar
I'm tempted to say square, because the vertical sides would better resist bending, but then again, I don't know **** about stress analysis.
edit: I can't spell
Old Aug 4, 2004 | 08:28 PM
Default Re: g3 DIY Trunk Brace question. (Mediocre Generica)
neither do i. but i think you are right about the squre becuase it will sit flat on the edges where i would bolt to the trunk.
Old Aug 4, 2004 | 08:42 PM
SJcivic's Avatar
Squares are stronger in one way (corner) than round... but on the flat sides there is they are basically butter (when compared to round). IF you knew exactly where the stress was coming from, and you could control the impact, direction, stress limit of the metal, etc (ie. God) then the sqaure would be a better choice.
Rich
Old Aug 5, 2004 | 08:41 PM
Default Re: g3 DIY Trunk Brace question. (SJcivic)
A round object will distribute weight or stress to the opposite side of the object were as a square object will distribute the weight or stress to the wall of that object. Think about a square, if you laid it on its side and moved it back and forth it wouldn't be very stable, if you did this to a ball or circular object then it would be more stable. If you look at any WELL MADE strut brace, you'll see that inside they used a spherical hole that travels the length of the bar. That hole helps with weight distribution. Round is better.
ILuvMyJdmDc4
May 13, 2007 12:21 PM
guessinthe2000
Feb 10, 2007 05:08 PM
It's*BOLO!!
24
Nov 3, 2006 10:54 AM
94BlueGSR
Sep 19, 2006 11:43 PM
kihun_cha
Honda Motorcycles
Jul 14, 2006 09:42 AM
