b16a oil filter?? which one? quick!!!
i currently have mobil 1 "m1-104" oil filter for my b16a gen2. it looks a bit bigger (in diameter) than my original filter...so i'm not sure if i got the right one. please help me out asap!!! i'm doing an oil change it's going to rain outside soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92CivicSiR2 »</TD></TR><TR><TD CLASS="quote">Go to napa or your local honda dealer and ask for a 99-00 civic si oil filter. </TD></TR></TABLE>
i'm using mobil 1 5w30...so i'll use mobil 1 filter. if i go and ask them, what if they tell me it's mobil 1 m1-104. someone knows if there is a difference between b16s and b18s oil filter? so i don't have to drive to autozone or o'reilly's and get recommended to the same filter.
call here:
1-800-882-0890
Mobile one hotline
i used a mobile one filter once. Then i had to use a kitchen knife to bust into it to get it off....
...all because i forgot to lube the seal and it's soo damn tight in that section i couldn't use the leather remover and my oil socket wrench wouldn't fit
i use oem now
1-800-882-0890
Mobile one hotline
...all because i forgot to lube the seal and it's soo damn tight in that section i couldn't use the leather remover and my oil socket wrench wouldn't fiti use oem now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFC »</TD></TR><TR><TD CLASS="quote">uuhhhh... I'm not really sure why it would matter if the b16a and b18's have the same oil filter, 99-00 si only came with a b16... which is what you asked for a filter for.</TD></TR></TABLE>
oops my bad for telling them i have a 94+ gsr motor. i forgot there's the 99-00 si's. my bad.
thanks all for the info. b16s and b18's use mobil 1 (m1-104)
