Adding aftermarket power door locks in a 92 civic.
Old Aug 4, 2004 | 11:42 AM
perfectsquare's Avatar
Default Adding aftermarket power door locks in a 92 civic.
So, my new civic's driver-side door lock is messed up. I was looking at lock cylinder replacements, but they are around $80+. I was thinking of just getting power door lock actuators, switches, etc. from a junkyard and putting them in place and getting a keyless entry system in place.
My question is. I have no power door locks now. Can I just plug the applicable parts into my 92 DX and have power door locks? Are all the plugs in place? Will it work mechanically?
Old Aug 4, 2004 | 12:15 PM
IVI's Avatar
IVI
Default Re: Adding aftermarket power door locks in a 92 civic. (perfectsquare)
i think if you get the appropriate parts off of a car that has them factory that it should basically be plug and play with the mechanical parts.
as for the electrical you might have to look into plugging them up for power and getting the harness's.
Old Aug 4, 2004 | 12:32 PM
rentacop's Avatar
Default Re: Adding aftermarket power door locks in a 92 civic. (IVI)
You can get a kit for like $80 iirc. (aftermarket)
Old Aug 11, 2004 | 10:03 AM
Default Re: Adding aftermarket power door locks in a 92 civic. (rentacop)
I actually worded this wrong. I'm just looking to see if I can take factory door locks/switches from a civic at a junkyard and plug them right into my existing non-power doors. Are the harnesses there, and all the wiring I need?
Old Aug 11, 2004 | 10:39 AM
john666's Avatar
If you wanted to do it you would need the harness under the dash and the harness in the doors, switches, etc.
eddieE
Honda Civic (2001 - 2005)
Nov 5, 2016 01:51 PM
thebriarman
Apr 9, 2012 10:06 AM
civicmark
Jun 7, 2002 05:59 PM
iNteGraz92
May 27, 2002 12:49 PM
mafiosetto
Jan 26, 2002 06:06 AM
