Brake pedal falling to the floor at stop lights on my 89 crx Si
Old Aug 4, 2004 | 11:26 AM
JDM2ndGen's Avatar
Default Brake pedal falling to the floor at stop lights on my 89 crx Si
Ok well this just started happening yesterday ...i was out running aroudn doing stuff all day and at some stop lights the brake pedal would fall to the floor ...i did a search and i couldnt come up with anything ...maybe it was my wording but what cuold cause thing ...a bad master cylinder?...heat? ...any help would be appriciated ...
p.s. i have another question that i didnt want to start another tread right after another ...i have the seats from my 92 integra which extremely mint ...what would i have to do to make the fit in my crx Si besides take of the manual seat belt stuff ...do i need the rails form my integra or do i use the rails from the crx ...any info would be greatly appriciated
thanks
Joe
Old Aug 4, 2004 | 11:30 AM
MR5 EF9's Avatar
Default Re: Brake pedal falling to the floor at stop lights on my 89 crx Si (JDM2ndGen)
bad master cyclinder replace that and youll be fine
93CivicSI's Avatar
Bleed your brake system (could be air in the system)
OR - your master cylinder and or power brake booster are going bad.
Old Aug 4, 2004 | 11:32 AM
JDM2ndGen's Avatar
Default Re: Brake pedal falling to the floor at stop lights on my 89 crx Si (93CivicSI)
yea i was thinking that there could be air in the system ...im going to check everything ...if i cant figure it out ill bring it to my friend over at honda ...
Mike_C's Avatar
is the pedal hard initially and then it gets soft?
is it always soft and just stays soft?
when you turn the car off and pump the pedal does it get hard?
if yes, then turn the car on, does the pedal get softer?
thanks
Old Aug 4, 2004 | 11:34 AM
JDM2ndGen's Avatar
Default Re: (MichaelJComputer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MichaelJComputer &raquo;</TD></TR><TR><TD CLASS="quote">is the pedal hard initially and then it gets soft?
thanks </TD></TR></TABLE>when i stop its hard then it gets soft afeter a couple of seconds ...i havnt tried with the car off ...im going to go outside and check right now ...
Old Aug 4, 2004 | 11:41 AM
Mike_C's Avatar
Default Re: (JDM2ndGen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM2ndGen &raquo;</TD></TR><TR><TD CLASS="quote">when i stop its hard then it gets soft afeter a couple of seconds</TD></TR></TABLE>
master cylinder is leaking. get one at your local automotive store.
Old Aug 4, 2004 | 11:44 AM
JDM2ndGen's Avatar
master cylinder is leaking. get one at your local automotive store.</TD></TR></TABLE>ok im going to get a price for one right now ...
Old Aug 4, 2004 | 12:01 PM
IVI's Avatar
IVI
did you even check the fluid in the reservoir?
to check the booster:
slightly hold your foot on the brake pedal
start car
when car is started brake pedal should slightly sink an inch.
Old Aug 4, 2004 | 05:13 PM
JDM2ndGen's Avatar
Default Re: (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">did you even check the fluid in the reservoir?
start car
</TD></TR></TABLE>checked the reservoir and it was on point ...and i checked with the car off and started it and the pedal did slightly sink about an inch ...im going to get a price on a master cylinder ...and towmorrow my friend whos a tech at honda said hes going to come and check it out for me and see what the problem is and then i will know for sure what to buy ...
Old Aug 4, 2004 | 05:17 PM
Chubakon's Avatar
damn i have the same problem on my 3rd gen teg.
when the car is off, the brake pedal is hard. - n when the car starts, (holding down the brake), it gets softer, bit by bit.
i dont have leak on my brake lines.
Old Aug 4, 2004 | 05:26 PM
JDM2ndGen's Avatar
Default Re: (94dc-er)
its doesnt get any softer when i 1st start it up ...its after a little bit of driving when i come to a light while im sitting there the pedal will slowly drop the the floor ...i just want to know for sure so i can get it fixed right away ...
Old Aug 4, 2004 | 05:57 PM
4DRmafia's Avatar
it the master clyinder
Old Aug 4, 2004 | 08:00 PM
ej1 pilot's Avatar
did anyone else find this hilarious?
Old Aug 4, 2004 | 09:41 PM
Chubakon's Avatar
Default Re: (Art In Motion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM2ndGen &raquo;</TD></TR><TR><TD CLASS="quote">when i stop its hard then it gets soft afeter a couple of seconds...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art In Motion &raquo;</TD></TR><TR><TD CLASS="quote">
did anyone else find this hilarious?</TD></TR></TABLE>
lol.. perverttt
any mơre suggestion for this prob.??
Old Aug 5, 2004 | 05:42 PM
JDM2ndGen's Avatar
did anyone else find this hilarious?</TD></TR></TABLE>lol that is pretty funny lol ...my friend checked it out today and said its one of the o-rings in the master cylinder ...so im going to be ordering a one and im also going to do my rear disc swap axles and etc ...while im at it ...thanks for the help and info guys ...its greatly appriciated ...
Old Aug 6, 2004 | 03:50 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM2ndGen &raquo;</TD></TR><TR><TD CLASS="quote">p.s. i have another question that i didnt want to start another tread right after another ...i have the seats from my 92 integra which extremely mint ...what would i have to do to make the fit in my crx Si besides take of the manual seat belt stuff ...do i need the rails form my integra or do i use the rails from the crx ...any info would be greatly appriciated</TD></TR></TABLE>
To swap the Integra seats into your CRX, you will need to swap the entire seat pan. It is not too difficult. A friend of mine installed '92 Integra seats in his '91 HF this way.
Old Aug 6, 2004 | 05:31 AM
DaWorm's Avatar
Usually my brakes are fine, but sometimes if I drive all day long and it is really hot outside, my car does this as well... I have to give myself almost double the stopping distance. I have brand new break pads on the car, but I do have 18" rims... Usually if I'm just driving around a bit, the pedal is firm and responsive. However, when I'm out for a long time, it's almost like the pads are melting onto my rotors... at least that is how the pedal feels... That's a master cylinder problem too? Thanks.
Old Aug 6, 2004 | 07:46 AM
gsrswapdcivic's Avatar
I had the same thing happen it was my rear caliper leaking might wanna check that.
Old Aug 6, 2004 | 03:13 PM
JDM2ndGen's Avatar
Default Re: (gsrswapdcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
To swap the Integra seats into your CRX, you will need to swap the entire seat pan. It is not too difficult. A friend of mine installed '92 Integra seats in his '91 HF this way.</TD></TR></TABLE>cool thats what i figured ...the Si seats have a rip in them and my 92 integra seats were mint ...it looks like no one has ever sat in them so i figured i have them might as well make use of them ... thanks for the info ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrswapdcivic &raquo;</TD></TR><TR><TD CLASS="quote">I had the same thing happen it was my rear caliper leaking might wanna check that.</TD></TR></TABLE>humm... im going to have the check that also ...if it is then it would give me more of a reason the swap to rear disc's ...
Veruka88
Oct 9, 2012 09:29 PM
jayeghatch
19
Jun 26, 2011 10:48 AM
snapon
May 16, 2008 09:27 PM
bambbrose
Oct 23, 2005 10:14 PM
luciffer
Aug 25, 2005 01:15 PM
