i feel grinding
whenever i shift from 2nd to 3rd, i can feel a grinding. i have a weak clutch that i'm saving up to replace. someone told me it could be my tranny. what can i do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobby_booshay »</TD></TR><TR><TD CLASS="quote">whenever i shift from 2nd to 3rd, i can feel a grinding. i have a weak clutch that i'm saving up to replace. someone told me it could be my tranny. what can i do?</TD></TR></TABLE>
Does it grind when rev matching?
when was the last time you change the tranny fluid.
i kno mines had a slight grind in second and 3rd. the tranny fluid was never replaced when i drained the fluid it was black
i usually feel it in high rpm.
what's rev matching?
i don't think the tranny fluid has been replaced in a while, i'll check in the morning.
thanks for the replies. mmmmm :]
i have the same problem as of right now... 2nd to 3rd - it grinds a little, i just swapped in the motor a weak ago. I changed tranny oil, and clutch m.c.(bled til no air bubbles)... if anyone has answers please respond thanks
Motor:
b18c1
Motor:
b18c1
