Tech question for the Vancouver guys (brake pad related)
Old Nov 28, 2001 | 04:46 PM
Kengs's Avatar
Default Tech question for the Vancouver guys (brake pad related)
Friend and I tried to install Project Mu Titan Kai pads (for EK4 Civic) on my '00 Si tonite; the front ones don't come close to fitting. Do you guys have this problem with your SiRs? TIA
Old Nov 28, 2001 | 04:55 PM
Big Phat R's Avatar
Default Re: Tech question for the Vancouver guys (kengs)
Where'd you buy them? Take them back if they don't fit.
Old Nov 28, 2001 | 04:57 PM
Kengs's Avatar
Default Re: Tech question for the Vancouver guys (Big Phat R)
Osaka
I'm thinking the US spec cars use a smaller caliper; hoping the BC guys can confirm this (i.e. if they have no fitment problems).
Old Nov 28, 2001 | 07:47 PM
Kengs's Avatar
TTT - hope you guys see this.
Old Nov 28, 2001 | 09:05 PM
Amuse9's Avatar
what do u mean wont fit??...is to big slightly??
Old Nov 28, 2001 | 09:19 PM
Kengs's Avatar
Default Re: Tech question for the Vancouver guys (jdmFERIO)
Yep, the Project Mus (fronts) are too big Rears fit perfect.
I sold a guy a set of NA-Y for the EK4, and he had the same problem. I just assumed the shop in Japan gave me the wrong set, but it seems like the JDM-spec EK4 front caliper is different from the Si.
I'm just wondering if the Canadian SiR has the same fitment problem.
Mike M's Avatar
Founding Member
I remember someone mentioning before that Endless pads for the EK4 need to be machined down a bit. Hope that helps Shane, Ben should know.
Old Nov 28, 2001 | 09:25 PM
Kengs's Avatar
Default Re: Tech question for the Vancouver guys (TypeRmsm)
Thanks Mike.
But how in the heck does one machine brake pads?
Old Nov 28, 2001 | 10:42 PM
AJ PwR's Avatar
hum hum !!! EK-4's caliper is completely different then the EM-1. EK-4 caliper will be the same as the Delsol VTEC EG-2 or EJ-1 Civic coupe Si/EX. We have tried some other pads to fit to the EM-1 and finally find something thats in the same shape but we just have to mill them about 1mm to fit cuz the pads were thicker.
[Modified by AJ PwR, 11:43 PM 11/28/2001]
Old Nov 28, 2001 | 10:46 PM
Kengs's Avatar
Default Re: Tech question for the Vancouver guys (AJ PwR)
Thanks Ben! You are the man!
1hOt95GsR
Jan 17, 2008 08:54 PM
JeremicaM
Honda Civic (2001 - 2005)
10
Jul 17, 2007 03:31 PM
Catch 22
Jul 18, 2005 03:23 AM
ragejed
May 7, 2004 05:08 PM
onyx00
Dec 13, 2001 10:23 AM
