Specs on stock SOHC non VTEC cam
Old Nov 28, 2001 | 04:02 PM
TheShocker's Avatar
Default Specs on stock SOHC non VTEC cam
Anyone know the following STOCK specs for the d16a6 cam?
1) Valve Life
2) Duration @1mm Int./Exh.
3) Adv. Duration
4) Lobe Separation
Thanks
-Seth
Old Nov 29, 2001 | 03:16 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Specs on stock SOHC non VTEC cam (miac1)
I've never seen the specs posted. I did measure to lope height on my CRX Si cam that I was using in a D15B7.
Doubt that info will help you though.
Old Dec 6, 2001 | 01:33 PM
TheShocker's Avatar
Default Re: Specs on stock SOHC non VTEC cam (Mista Bone)
Hmm, probably not...thanks anyway though!
Anyone else know?
-Seth
Old Dec 14, 2001 | 09:10 PM
TheShocker's Avatar
Ok what the heck, what was that measurment that you took?
Thanks
-Seth
Old Dec 14, 2001 | 10:11 PM
Mista Bone's Avatar
D Tranny Guru
CRX Si 1990
Intake
base height 1.220, lobe 1.445, .225" lobe lift = .374" valve lift
Exhaust
base height 1.262, lobe 1.455, .193" lobe lift = .353" valve lift
Gude #HCCS07 (regrind)
Intake
base height 1.135, lobe 1.385, ..250" lobe lift = .415 valve lift
Exhaust
base height 1.170, lobe 1.400, .230" lobe lift = .421 valve lift
Gude lists duration @ 241I/228E for that cam.
Hope this helps.
Old Dec 15, 2001 | 11:25 AM
TheShocker's Avatar
Thanks man!
-Seth
Old Dec 15, 2001 | 11:48 AM
TheShocker's Avatar
Is that Gude a pretty aggressive cam grind? I was looking at the Crane turbo cam which has .394/.376 intake/exhaust valve lift. Which isn't as aggressive as the Gude one you posted..
-Seth
Old Dec 16, 2001 | 12:11 AM
Mista Bone's Avatar
D Tranny Guru
Likely Gude specs are "overrated".........
Old Dec 16, 2001 | 12:41 PM
89civicdx's Avatar
how do you calculate the lift
Old Dec 16, 2001 | 10:01 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Specs on stock SOHC non VTEC cam (89civicdx)
lobe height - base height = lobe lift
lobe lift x rocker ratio = valve lift
kornerk12
Aug 16, 2010 11:31 PM
Dark91zc
Jan 6, 2006 03:27 PM
crx_88_si
May 12, 2004 07:47 PM
CrXr89Si
Feb 17, 2004 11:14 PM
TheShocker
Dec 15, 2001 11:26 AM
