93 ex to h22 swap info needed!!!!!
what will i need to swap my 93 ex to an h22?
i know some accords came with h22s but not 93.. its obd-1 so im wondering what all will i need mounts/axels and what wires need to be added.. knock,2nd o2 v tec etc??
thank for any info you can share
do a search! ..
is ur motor obd1 or 2? Your gonna need to tap the h22a tranny in order for it sit straght!! You use all accord mounts, accord axles.. and you use ur accord HALF SHAFT as well! you use ur accord engine harness, and just run the extra wires for VTEC pressure switch, VTEC solionid (sp?), IAB's (unless you have a f22a6 then you already have that on your accord harness) and KNOCK SENSOR..
buy a helms too ! comes in handy!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hater2587 »</TD></TR><TR><TD CLASS="quote">
no usdm accord ever came with an h22
