factory fog light install
Old Aug 2, 2004 | 10:16 PM
pre1udekid's Avatar
Default factory fog light install
hey i just got factory fogs and the switch for my 95 vtec luda and i was wondering what to do i now have the switch and lamps installed but they dont come one. help please. i searched for this topic but could not find it..
Old Aug 2, 2004 | 10:19 PM
Chris1091's Avatar
Default Re: factory fog light install (pre1udekid)
Did you hook them up to a power source of some sort?
Old Aug 2, 2004 | 10:22 PM
pre1udekid's Avatar
Default Re: factory fog light install (Chris1091)
i plugged them into the pluggs where there supposed to plug into but that else do i have to do does it not power it through there?
Old Aug 2, 2004 | 10:25 PM
Chris1091's Avatar
make sure your fuses and relays are alright.
Old Aug 3, 2004 | 03:41 AM
94vtirozguy's Avatar
did you plug in the foglight sub-harness or did you not get one, if not your going to have to make one up yourself.
Old Aug 3, 2004 | 05:32 AM
thehondaguru's Avatar
you need to add in a relay. you can find complete instructions here
http://www.hondaautomotivepart....html
And you DO NOT need the subharness. its only purpose is to extend the exsisting harness a little further. Just buy a 4 prong relay and your good to go.
Old Aug 3, 2004 | 06:00 PM
Default Re: factory fog light install (95 lude)
wtf you talking about ?
you DO need to make subharness how do you think the relay is going to fit in the connector under the dash ????
the harness needs to be made up to fit between the stock connector and relay.
chillerice
Nov 27, 2011 05:20 AM
MudBggn
Nov 3, 2011 10:51 PM
bryanjenks
Lighting
Nov 25, 2010 07:51 PM
AreJay126
Jun 16, 2006 01:13 PM
OEM_ASSASSIN
Sep 24, 2005 04:33 PM
