Which is faster Non V-Tech H23 or V-Tech H22?
Old Aug 2, 2004 | 10:12 PM
honestabe's Avatar
Default Which is faster Non V-Tech H23 or V-Tech H22?
I am buying a car from a guy with a non V-tech H23 but I wanted a V-Tech H23. Would the non vtech still be faster than the H22 vtech? What could I do to the H23 to make it faster?
Old Aug 2, 2004 | 10:18 PM
Nikoli's Avatar
Default Re: Which is faster Non V-Tech H23 or V-Tech H22? (honestabe)
the h23 is only non vtec and the h22 is vtec which also has more hp
you should read this as it will answer most of your questions https://honda-tech.com/zerothread?id=689805
Old Aug 2, 2004 | 10:19 PM
UA6 BALLER STATUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honestabe &raquo;</TD></TR><TR><TD CLASS="quote">I am buying a car from a guy with a non V-tech H23 but I wanted a V-Tech H23. Would the non vtech still be faster than the H22 vtech? What could I do to the H23 to make it faster?</TD></TR></TABLE>
Its VTEC not VTEK, vtech, vetec ect.
4th gen preludes
93-96 Honda Prelude Si h23 DOHC 2.3 liter 160 hp 156 TQ compression ratio 9.8:1
93-96 Honda Prelude VTECH22 DOHC VTEC 2.2 liter 190 hp 158 TQ Compression Ratio 10.0:1
stock for stock the VTEC model is faster, but the Si is a little bit lighter.
pre1udekid's Avatar
the h22 vtec is faster get vtec
Old Aug 2, 2004 | 10:20 PM
DsITR's Avatar
The H22 is quicker than the H23. It makes more horsepower and revs higher.
The H23/vtec is a good build to look @. basically retain H23 torque, but gain some top end.
Also the H23 is more boost friendly if you plan on turbocharging.
All let some of the experts eh-splain and to accomodate the others might wanna edit your post.. vtec doesn't not have a H
Old Aug 2, 2004 | 11:33 PM
H22CB7's Avatar
vtec owns
Old Aug 3, 2004 | 01:38 AM
satan_srv's Avatar
Default Re: (H22CB7)
geez...like people said there is no VTEC h23 available in any model here
PreLuDeSiR
May 20, 2005 11:19 AM
foshizllmynizl
Aug 21, 2004 03:41 AM
hOndafienD 04
Jun 12, 2004 06:58 AM
PreludeMTX
May 8, 2004 09:38 PM
accordianex
Mar 4, 2002 09:17 AM
