H22 ECU HELP?????
Gettin ready for the swap and need suggestions on the ECU..i noticed that BIG JAMESss uses a GS-R ecu (does that help over the stock h22 ECU)but 4drH22 uses stock ECU help me out guys....Thanks for all imput
[Modified by TEK4DR, 10:46 PM 11/28/2001]
Just a note, there is no Hondata program past stage 1 for the H22 ECUs, if u want to go higher and want their boost program you need a GSR ECU or another similiar ECU.
https://honda-tech.com/zerothread?id=65607
This thread will show you the good and bad about a stock GS-R ECU driving a H22. It will give you more top end power, but the VTEC crossover has the H22 bogging down in the middle, but that can be easily fixed. I still prefer the P13 however.
I'm holding off on Hondata until they fully decode the P13.
