CRX window off track, need help!
Ok, well my passenger window of my crx fell off track when i went to roll it down.
I took the panels off, and all and the window sits on the track, and is like glued in to it with this adhesive. Its not like civics, because i think they have screws that go through it.
My question is where can i get this adhesive, im not trying to pay a shop to fix it, i mean ive done all the work, and i called one and they said they couldnt do it!
so anyone can help thanks!
No the glass fell out of the track, and its held in by an adhesive not by a screw or anything. I called a glass shop and they said they couldnt do iT??? i was like ok, thats what you do!!
thanks
thanks
theres no adhesive in yer tracks or nothin like that
all ya gotta do is take out the 4-5 10mm bolts behind the door panel and 1 small screw behind the mirror panel that hold yer track in place
(theyre there.... trust me)
hold onto yer window cuz it might fall if it aint already down all the way
after that, line it all back up and put the rear side of the track in place first
after the front are back in too it should all work again
if it dont, then ya prolly melted the rubber trim around the window which sucks but aint much harder to replace
Yea its the adhesive that holds the window to the holder, which attaches to track by two 10 mm bolts.
The adhesive has came unloose and if you need pics ill post them. I talked to elmalouno about it, he knows what im talking about.
Im going to try what he said, to use the strongest epoxy out and let it sit for a day or two, then put it back in. thanks guys
00ekcoupe
13
Aug 27, 2005 10:52 AM
EnKidu
Oct 12, 2004 07:08 PM
