Is my ECU crap?
Ok i started the car drove for 100ft shifted to second and the car died. The check engine light flashes and clicks and so does the ECU. No codes it just flashes really fast. Is the ECU dead? Anyway I can check it ? And if its dead can i use an ECU out of an non-SI civic (mine is an 89 si)?
Thanks guys.
Thanks guys.
Needs to be About 20% Cooler
Some more info would help. T-Mo's stuff and does the engine start and run or run with a low rev limit? OBD 0 or 1? any engine codes?
89 Si, stock D16A6, stock ECU.
This happened 30 min ago. I started the car went to first gear and as soon as i shifted to second it died and will not start again.
The CEL is blinking rapidly and the ecu keeps flashing. No codes it just flashes without ending
cranks over and over?
check injector wiring for loose or disconected plugs or blown fuses.
the cel shouldint blink at all if it's obd0. count the blinks on the ECU and get back to us.
it does crank over but doesnt start.
checked the injectors and plugs.
because the cel is flashing rapidly and ecu is just flashing with no codes, is making me think its either a short somewhere or the ecu is dead
but how can an ecu just die while driving?
thats the problem. i dont.
i was thinking about going to the junkyard tomorow but i know they dont have any si's. do you think i can use an ecu from a 4-door ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan4g63 »</TD></TR><TR><TD CLASS="quote">thats the problem. i dont.
i was thinking about going to the junkyard tomorow but i know they dont have any si's. do you think i can use an ecu from a 4-door ?</TD></TR></TABLE>
it couldint hurt. I dont think theres a diffrence between a HB and a sedan ecu. make sure both are manuals.
Modified by JC18 at 9:05 PM 8/2/2004
the ecu u use has to be from a civic Si or a Civic EX. the DPFI ecus will not work. i can send you a spare PM6 (ur ecu) to borrow if u pay shipping but i dont know if you wanna wait that long
crookson speed
Feb 19, 2014 01:32 PM
bk7794
May 29, 2012 09:32 AM
drumminforev
19
Oct 6, 2006 12:12 AM
impact_blu
Aug 18, 2005 01:36 PM
