3rd gear grinding
Old Aug 2, 2004 | 07:09 PM
rcurry14's Avatar
Default 3rd gear grinding
If third gear grinds sometimes when you go into does that mean that the tranys going bad because someone told me it could be the syncros. Or would it be that the clutch is going bad.
Old Aug 2, 2004 | 07:10 PM
RinBlue's Avatar
Default Re: 3rd gear grinding (rcurry14)
most likely its your synchros
Old Aug 2, 2004 | 07:12 PM
len's Avatar
len
Did you depress the clutch all the way? Sounds elementary, but solves a good bit of tranny grinding problems.
Old Aug 2, 2004 | 07:16 PM
R you serious's Avatar
3rd gear syrcro is going. weak point of b series trannies.
learn to double clutch and save your new one
Old Aug 2, 2004 | 07:26 PM
rcurry14's Avatar
This may be a stupid question but how much would it be to replace the syncros or could i just take them out and just double clutch all the time.
Old Aug 2, 2004 | 07:27 PM
justinh595's Avatar
Default Re: 3rd gear grinding (R you serious)
double clutching is for dump trucks. What fluid are you running in the trans?
Old Aug 2, 2004 | 07:33 PM
rcurry14's Avatar
i dont know i just got the car and it is a project car. It is wrecked as you can see in the sig and i havent really got it on the road yet to see if it really does grind. The previous owner told me that it did this occasionally. If I would switch to a oil like redline oil would that stop it for now.
Old Aug 2, 2004 | 07:36 PM
Default Re: (rcurry14)
must have missed that in your sig, oh wait, you dont have one
Old Aug 2, 2004 | 07:37 PM
Bbasso's Avatar
Keep replaceing the MTF with Honda's MTF every 10k untill you can replace the syncros
Old Aug 2, 2004 | 07:38 PM
.RJ's Avatar
.RJ
Default Re: (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Keep replaceing the MTF with Honda's MTF every 10k untill you can replace the syncros </TD></TR></TABLE>
My tongue is bleeding.
Old Aug 2, 2004 | 07:40 PM
Bbasso's Avatar
Default Re: (.RJ)
Old Aug 2, 2004 | 08:26 PM
rcurry14's Avatar
sorry i ment avatar
Old Aug 2, 2004 | 10:15 PM
igotswansons's Avatar
heres how to test synchros.. well this is how the tranny guy showed me.. it works tho cuz we tested it on my friends b-series tranny
his 3rd grinded too everytime but the test is u downshift from 4th to 3rd.. if it doesnt grind downshifting from 4th then its your slider... if its the synchro, then it will grind equally down and up shifting...
Old Aug 3, 2004 | 06:21 PM
justinh595's Avatar
Default Re: (igotswansons)
My trans when I got it would grind 3rd gear from 4000 rpms and up no matter how I shifted. I switched to gm syncromesh (buy at any gm dealer) and it fixed the problem. It doesn't seem to work right away. After about 700 miles with it in I noticed much smoother shifts all around and the grinding completely stopped. I now shift at 8700 and it doesn't grind at all. I can't say enough good things about gm syncromesh, I think it saved my trans.
gabe768
Jun 7, 2010 03:06 PM
4everVtec
Mar 9, 2007 12:23 AM
misoshiru_akira
Feb 26, 2007 06:29 PM
B18cteg
Jul 3, 2003 10:18 AM
Brandon
Jul 31, 2002 09:59 PM
