swaping valve cover help
Old Aug 2, 2004 | 06:26 PM
Dc2 Powered's Avatar
Default swaping valve cover help
well i got a b18c1 and got a jdm itr valve cover for it and a new gasket, but my friend keeps telling me i need new "gorment" or "Gormets" or whatever its called and i need 4 .. do i really need to replace these?
Old Aug 2, 2004 | 06:29 PM
esponet's Avatar
not really, but its a good idea.
Old Aug 2, 2004 | 06:30 PM
hellrazr1208's Avatar
Default Re: swaping valve cover help (Dc2 Powered)
I believe he is refering to the grommet/gasket for the spark plugs. You might be able to reuse the ones on ur current valve cover but I would replace them, depending on cost-- if they are cheap then definitely. If you want to reuse the old ones make sure there are no small cracks and that they havn't hardened up.
Old Aug 2, 2004 | 06:31 PM
GTXgp's Avatar
I got my new valve cover gasket from O'Reilys and it came with all 4 new spark plug grommets... just FYI
Adam
Old Aug 2, 2004 | 06:40 PM
well i already have a gasket and he said the grommets cost a couple bucks each
Old Aug 2, 2004 | 06:44 PM
mr.beeks's Avatar
Default Re: (Dc2 Powered)
they are calle
grommets.
and they are not the ones that go on the sparkplugs...
they are the ones that actually hold up your
valve cover..
a cheap valve cover gasket set will not include them
so go to acura dealer and pick them up for penies.....
Old Aug 2, 2004 | 07:32 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (mr.beeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">so go to acura dealer and pick them up for penies.....</TD></TR></TABLE>
Just FYI, from the dealer, they are like $2something each.
Old Aug 3, 2004 | 12:16 AM
ic.. these are the same for the b16a2 off the 99-00 si so i could just go to honda-world right?
Old Aug 3, 2004 | 04:08 AM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc2 Powered &raquo;</TD></TR><TR><TD CLASS="quote">ic.. these are the same for the b16a2 off the 99-00 si so i could just go to honda-world right?</TD></TR></TABLE>
thats right.......
Old Aug 4, 2004 | 01:55 PM
TrueUntilDeath.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">they are calle
grommets.
valve cover..
nope, we are talking about the one that goes under the spark plugs under the valve cover.
Old Aug 4, 2004 | 04:15 PM
shamoo's Avatar
Default Re: (GMR MM12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GMR MM12 &raquo;</TD></TR><TR><TD CLASS="quote">
nope, we are talking about the one that goes under the spark plugs under the valve cover.</TD></TR></TABLE>
Yes, that's what he's talking about. They actually give the valve cover support under there and "hold it up." If they weren't there, the oil would leak freely into the spark plug hole area.
Grommets
Old Aug 4, 2004 | 09:48 PM
Default Re: (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">
Grommets </TD></TR></TABLE>
got ya, thanks for clearing it up
Old Aug 4, 2004 | 11:15 PM
SMZ GSR's Avatar
Get new ones. Oil in cylinder = suckage. They are cheap and yes 99-00 Si is the same
depo
Mar 23, 2019 09:37 PM
Midori Green
Jun 1, 2007 10:53 AM
dc5tegk20
Aug 24, 2006 12:40 AM
Browneye
Sep 25, 2004 07:05 PM
HONDA-2NR
18
Mar 7, 2004 07:13 PM
