ok i know, another ls/vtec? but i need to get this striaght!
Old Aug 2, 2004 | 05:59 PM
aziz93's Avatar
Default ok i know, another ls/vtec? but i need to get this striaght!
Alright, if you've been over this topic a hundred times, sorry and thinks, for giving it another chance. If you come on here to tell me to search dont bother i already wasted an hour and a half searching.
What I have=a stock jdm 2nd gen b16a head complete all the way to the injectors-minus- the dist../ usdm b18b LS stock block with 44,000 miles/ jdm b16a trans... 7.5 lb flywheel
Main question is will a virgin p28 ecu be best with this setup (staying all-motor for now) if I need to get it chipped which one, and will the ls dist.. work with the b16 head? If it does will it be good enough? Finally will i have to get a header for a b16?
I know when there is a lot of questions asked they usually dont all get answered so if that is too many questions i need to know about the ls dist.. and what up with the ecu? Thanks
Old Aug 2, 2004 | 06:08 PM
rough_draft's Avatar
stock bottom end? i hope not.. ARp rod bolts are a must, save ur engine for less than 100 bucks.. same wtih arp head bolts.. as for the ecu question idk
Old Aug 2, 2004 | 06:13 PM
3.504's Avatar
Default Re: ok i know, another ls/vtec? but i need to get this striaght! (aziz93)
p28 has a 7500ish rev limit. can't really remember. but i do know it'll throw a CMP code since theres 2 cams there instead of just 1. other than that, it'll be fine. the LS distributor will work fine, if you hack the leg that the vtec sol. interferes with. only 1 bolt (unless you drill a hole in the back leg, the top leg will line right up) will hold it on, so tighten it down pretty good and use lock tite after you get your base timing on. as for the header, your LS header/exhuat mani will bolt right up.
Old Aug 2, 2004 | 06:22 PM
aziz93's Avatar
Default Re: (rough_draft)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rough_draft &raquo;</TD></TR><TR><TD CLASS="quote">stock bottom end? i hope not.. ARp rod bolts are a must, save ur engine for less than 100 bucks.. same wtih arp head bolts.. as for the ecu question idk</TD></TR></TABLE>
Yes, thanks, but I got all of that under control. I left a lot out to try to keep it simple, and not loose track of the subject.
gabe768
May 26, 2009 11:15 AM
masijdm
Mar 22, 2009 01:43 AM
bboysake
Jul 10, 2006 09:44 AM
timm099
Feb 16, 2006 01:31 PM
