Wheel Bearing
Old Aug 2, 2004 | 03:19 PM
AllSpedup04's Avatar
Default Wheel Bearing
My wheel is making alot of Noise i think i need to change my Bearing , is this hard? does anyone have a Guide for changing the front wheel bearings? thanks
Old Aug 2, 2004 | 04:01 PM
Default Re: Wheel Bearing (AllSpedup04)
Anyone please?
Old Aug 2, 2004 | 06:48 PM
dc4drewH's Avatar
the bearing are usually about 40 bucks, gotta get the sealed bearing pressed in, while your at take the ugly brake dust sheild off!
Old Aug 2, 2004 | 07:42 PM
SOHCejcivic's Avatar
it's not too hard, like he said^^ you have to have it pressed in.
pretty much all you have to do is...
jack it up, take off whichever wheel
take off the axle nut
take off rotor/caliper
disconnect the knuckle from the 3 points (upper/lower lca, steering)
slide out the axle
take the knuckle to a shop and have it pressed in
reverse and put it back together
the only thing you want to try to do is not tear up the ball joints/pillow mounts (little rubber boots at 3 connections) otherwise they will click and annoy the **** out of you.
GotGSR's Avatar
Default Re: Wheel Bearing (dc4drewH)
tighten all lugnuts first...that might be your problem
Old Aug 2, 2004 | 07:54 PM
Dan GSR's Avatar
Default Re: Wheel Bearing (SOHCejcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCejcivic &raquo;</TD></TR><TR><TD CLASS="quote">it's not too hard, like he said^^ you have to have it pressed in.
slide out the axle
the only thing you want to try to do is not tear up the ball joints/pillow mounts (little rubber boots at 3 connections) otherwise they will click and annoy the **** out of you.</TD></TR></TABLE>
lol
not much of a how to
Old Aug 2, 2004 | 07:55 PM
Dan GSR's Avatar
Default Re: Wheel Bearing (Dan GSR)
https://honda-tech.com/zerothread?id=720159
Old Aug 3, 2004 | 08:24 AM
Thanks guys
Old Aug 3, 2004 | 09:26 AM
dip-set's Avatar
i think i need a passenger wheel bearing as well..what are symptoms of a bad wheel bearing,the only symptom i have is a humming sound when im driving,the wheel doesnt wobble at all,ive tried shaking the hud in all directions,but its all tight,nothing moves...any info appreciated..
Old Aug 3, 2004 | 09:51 AM
Dan GSR's Avatar
Default Re: Wheel Bearing (b18b-se)
lossen the axle nut
put the car in the air, and try to rock the wheel holding it at 12 and 6
if there is play it is the wheel bearing
Old Aug 3, 2004 | 10:13 AM
dip-set's Avatar
cool,thanks dan
the learner
Jan 20, 2014 11:35 PM
VTECROAR96typeR
Suspension & Brakes
Mar 3, 2009 12:38 PM
B18c1_turbo
Mar 14, 2008 10:43 AM
spyderazn
Mar 9, 2008 05:28 PM
