Stock VTEC settings for a H22
Old Aug 2, 2004 | 03:14 PM
93acclude's Avatar
Default Stock VTEC settings for a H22
What are the stock VTEC settings for a JDM H22? there is a low VTEC and a high VTEC. The high VTEC is 5600rpm but i dont know the low setting. Also which would make more power. On the low VTEC if you dialed it in lower (3500rpm) would it make more power than if you set it at (4900rpm). i have an Apexi VTEC controller.
Old Aug 2, 2004 | 03:37 PM
satan_srv's Avatar
Default Re: Stock VTEC settings for a H22 (93acclude)
there is no low VTEC and high vtec
VTEC crossover is 4900 on a 4th gen JDM h22a.
If mean on a v-afc the low is when it drops out..I usually only set it 100-200 lower just incase I miss a little on the shifting but that was when my car was stockish. it's just to keep you in vtec below the crossover rpm so you don't 'drop out'
96accordexproject
Nov 7, 2008 04:55 PM
-Bionic-
Oct 16, 2003 09:06 AM
Excelerate
Sep 21, 2003 08:14 PM
Detroit
Jul 11, 2002 01:59 PM
accord5speed
May 9, 2002 08:09 AM
