Tein SS question. Need some help
Old Aug 2, 2004 | 02:21 PM
cibola's Avatar
Default Tein SS question. Need some help
I have a 98 GSR DC2. 3 months ago I installed the Tein SS's on my car. All of a sudden I hear a pretty visous squeek comming from what sounds like the top of the strut on rear of the car. It sound almost like rubber on metal.
I have done 1 NASA event on the tein's and the car is my daily driver. I have put aprox 700 miles on the struts since the install. They have adjustable dampening, when running the track i was 4 clicks down from full stiff and daily I have it on 12 clicks down. The springs are cranked up pretty high only lowering my car about one and one half inches from stock.
Someone has said that the struts are probally blown and i need them rebuilt, but the set-up is only 3 months old with 700 miles.
Anyone have any ideas?
Please help
Old Aug 12, 2004 | 08:35 AM
cibola's Avatar
Default Re: Tein SS question. Need some help (Cibolawins)
tt
Old Aug 12, 2004 | 09:14 AM
chicows18's Avatar
is the nut that holds the assembly (on top of the shock/strut) together on tight. Check and make sure its not loose. Also, Tein specifies what they think is a best setting as far as ride height, did you change from what they specifify. If so, did you compress the spring more using the two nuts or just move on up or down with the threaded black stem with the single nut that holds it in place once set.
Old Aug 12, 2004 | 09:36 AM
cibola's Avatar
Default Re: Tein SS question. Need some help (chicows18)
I compressed the 2 nuts to raise the vehicle. I will need to remove the strut to make sure that the top center nut is tight, when I tryed to tighten it it started to spin the whole shaft, I stopped after about an 1/8th of a turn.
Old Aug 12, 2004 | 09:59 AM
chicows18's Avatar
Try it with an impact gun. But dont over do it.
Old Aug 12, 2004 | 02:52 PM
krazie1's Avatar
BANNED
have SS's too and sounds like the nut is loose
and teins can really only be adjusted only so much the valve inside ain't meant to go up and down or the dampening that much
I have mine to 4 and 2 nothing more don't want to **** them up
Old Aug 13, 2004 | 01:20 AM
suspendedHatch's Avatar
Default Re: Tein SS question. Need some help (krazie1)
If the whole shaft spins you use an allen wrench and a wrench not a ratchet.
Old Aug 13, 2004 | 08:28 AM
cibola's Avatar
Default Re: Tein SS question. Need some help (shaundrake)
Thanks for the help illl let you guys know how it goes when i do it this weekend.
BluSmokes
Mar 1, 2006 10:07 PM
s-type
Dec 13, 2005 03:13 PM
jdmwestcoaststyle
Suspension & Brakes
Sep 27, 2005 04:32 AM
brian2903
Apr 28, 2005 07:33 AM
