What does this line do? *pic*
In this picture, the line that goes from the intake manifold to the middle of the valve cover....is it just any old vacuum line, or does it have a specific purpose? I know b16s dont have this, so im kinda curious.
The plastic 'elbow' on the valvecover end of that hose IS the PCV valve. Lots of B-series engines have the valve located on a breather box on the backside of the block (Underneath the intake manifold). So on the B16 or whatever, YES IT DOES HAVE THAT. It's just located differently.
The PCV valve lets the manifold vacuum suck air out of the crankcase. Then fresh air is sucked in thru the breather hose. The stock breather hose comes from the intake tube, but in the picture it's been replaced by a filter (just above the oil fill cap).
Don't use that for a vacuum source! The line from the valve cover can get oil going thru it.
Hence why its called a Pressure Control Valve.
Run the BOV off the brake booster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">The plastic 'elbow' on the valvecover end of that hose IS the PCV valve. Lots of B-series engines have the valve located on a breather box on the backside of the block (Underneath the intake manifold). So on the B16 or whatever, YES IT DOES HAVE THAT. It's just located differently.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">
Either way, I wouldn't connect anything to it, cause of the likelyhood of oily air flowing thru it.</TD></TR></TABLE>
good advice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">Either way, I wouldn't connect anything to it, cause of the likelyhood of oily air flowing thru it.</TD></TR></TABLE>
good advice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote"> Then fresh air is sucked in thru the breather hose. The stock breather hose comes from the intake tube, but in the picture it's been replaced by a filter (just above the oil fill cap).
Have you taken off a breather line?? The air comes out of the engine. Air enters the engine from the combustion chamber, caused by blow-by pased the pistion rings. There is no airflow from the manifold into the valve cover. Air flows from both the crankcase and valvecover into the intake manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">Have you taken off a breather line??</TD></TR></TABLE>Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">There is no airflow from the manifold into the valve cover.</TD></TR></TABLE>Correct. The manifold has lower pressure so it flows from the engine, thru the PCV valve, into the manifold. It's the breather line that reverses flow direction under some conditions. Like when the blowby overwhelms the capacity of the PCV line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89preludesi »</TD></TR><TR><TD CLASS="quote">actualy its positive crankcase ventilation </TD></TR></TABLE>
That is correct
That is correct
JerseySiPOS
12
May 16, 2004 10:40 AM
