Question About My Tach
The stock tach and the aftermarket tach aren't exactly even. The aftermarket one is always like a couple hundred rpm's higher than the stock one, is this normal? Also once the car gets warmed up the stock tach drops down to 0 rpm's. It's a Integra GSR btw, is this normal? Sorry for the big pic.
stock tachs are known to be off by a few hundred rpm.. give or take
edit- here's a thread for your reading pleasure. https://honda-tech.com/zerothread?id=626056
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Your stock tach should never drop to 0rpms when warm. That can't be good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMThoughts »</TD></TR><TR><TD CLASS="quote">Your stock tach should never drop to 0rpms when warm. That can't be good.</TD></TR></TABLE>
Any ideas on what could be the problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beezle »</TD></TR><TR><TD CLASS="quote">Any ideas on what could be the problem?</TD></TR></TABLE>
Does the tach just drop to 0rpm and the car stays idling just fine? Or does the car die?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo »</TD></TR><TR><TD CLASS="quote">
Does the tach just drop to 0rpm and the car stays idling just fine? Or does the car die?</TD></TR></TABLE>
The car stays idling fine.
THE GREEN WIRE ON TOUR TACH MAKE SURE IS REALLY WELL TIE UP TO THE BLUE WIRE BY YOUR DISTRIBUTOR AND ASLO PUT ELEKTRIC TAPE ARROUND IT
YOUR AFTERMARKET SHOULD BE THE SAME RPM AS YOUR STOCK TACH
CINCE THEY ARE WORKING WITH THE SAME WIRE (BLUE)
AND IF YOUR CAR IDLES FINE BETWEEN 1 AND 0 IS OK AS LONG IT DOESN'T FEEL LIKE IS GOING TO DIE
HOPE THIS HELP U
HOPE THIS HELP U
vteczone
Dec 18, 2003 08:13 PM
