Civic Won't Start in the Morning but works at night.
Old Aug 2, 2004 | 08:13 AM
Daysleeper15's Avatar
Default Civic Won't Start in the Morning but works at night.
Hi, I have a manual transmission 1990 Civic LX with 172K miles. The car has been running fine, then out of the blue it wouldn't start last Thursday morning. The engine cranks but the car wouldn't start. However when I came home from work arournd 7:00 that night the car started with no problem. I had the same problem on Friday, Saturday, Sunday and this morning. Each day, the car starts finr at night. What could this be? Thank you. Jim.
Old Aug 2, 2004 | 08:42 AM
mrchaos's Avatar
Default Re: Civic Won't Start in the Morning but works at night. (Daysleeper15)
whats the weather been like there?
Old Aug 2, 2004 | 08:50 AM
halfmillion's Avatar
My 2000 cx has the same problem, usually it starts, it didn't start Tuesday and Sunday morning, however I have over 600 hundred thousand kilometers on it, could it be the fuel filter? the weather has been fine.
Old Aug 2, 2004 | 09:08 AM
mrchaos's Avatar
Default Re: Civic Won't Start in the Morning but works at night. (halfmillion)
holy crap....600,000?!?! got pics?
halfmillion....i would check your filter
daysleeper....i would check you fuel filter....has it been hot out on those days you listed?
Old Aug 2, 2004 | 09:18 AM
Default Re: Civic Won't Start in the Morning but works at night. (mrchaos)
I am in NYC. It has been hot, if you consider mid 80s hot. Still think I should check the fuel filter? What do you mean by check it? Do you mean replace it, and how can I tell if it is the fuel filter.
Old Aug 2, 2004 | 09:24 AM
mrchaos's Avatar
well replace it, its a $20 part and cant hurt.....
but 80's is hot enough to cause starting problems....it can make the fuel in the lines go watery and the car wont start...but as it cools down the car will start
Old Aug 2, 2004 | 09:57 AM
Thanks, I'll try and replace the fuel filter. Does anyone know where I can get information on how to change a fuel filter?
Old Aug 2, 2004 | 10:02 AM
Kaan's Avatar
Loved
Community Favorite
my CRX does that.... do a test.... leave your window cracked .... if it starts its your main relay.... it gets hot and doesnt like working.... thats a $50 fix from the honda dealer.... well from the parts counter.
Old Aug 2, 2004 | 10:12 AM
You can buy a filter at an auto parts store.
mr chaos I don't have a picture but it looks like any regular balck civic except for the insects pasted on the front bumper.
I just replaced the rad, the orginal one is responsible for the death of tens of thousands of insects.
D
Old Aug 2, 2004 | 10:23 AM
green91's Avatar
main relay
Old Aug 2, 2004 | 10:24 AM
crown14's Avatar
MAIN RELAY
Old Aug 2, 2004 | 10:27 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Civic Won't Start in the Morning but works at night. (MMsportsRexSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MMsportsRexSi &raquo;</TD></TR><TR><TD CLASS="quote">my CRX does that.... do a test.... leave your window cracked .... if it starts its your main relay.... it gets hot and doesnt like working.... thats a $50 fix from the honda dealer.... well from the parts counter.</TD></TR></TABLE>
Also listen for the fuel pump to come on when you turn the key to the ON position.
If it doesn't come on then it's most likely the main relay.
uncommenartist
Classic Hondas
Jan 27, 2015 02:30 PM
pyroom
12
Jan 23, 2012 08:35 PM
kevinm1981
Jul 12, 2009 01:40 PM
Integra4lyfe069
15
Mar 10, 2009 02:51 PM
zach1288
Nov 16, 2006 12:20 PM
