What is the best way to break the exhaust free?
Old Aug 2, 2004 | 04:22 AM
amb4081's Avatar
Default What is the best way to break the exhaust free?
I am attempting to replace the muffler on my wife's 1991 Accord DX. The bolts/nuts are in good shape; not too corroded by the elements. But they are on there TIGHT!!! I tried PB blaster but can't seem to get them loose. I have a torch if it comes to it that I can heat them up. Any recommendations? Thanks.
Old Aug 2, 2004 | 05:03 AM
FatJoe's Avatar
Default Re: What is the best way to break the exhaust free? (amb4081)
good ol' MAN POWER! if you dont have an impact gun, then try putting a wrench on em... and then slip a large pipe on the hangle of the wrench, and by doing this you have more leverage and therefore more torque to work with. if it doesnt work (keeps fallin off, no luck) then hell, flamethrower time!
Old Aug 2, 2004 | 05:21 AM
amb4081's Avatar
Default Re: What is the best way to break the exhaust free? (FatJoe)
I will try my friend's impact. Then torch it if that doesn't work! hehe. Thanks guys.
Old Aug 2, 2004 | 06:53 AM
notoriousB's Avatar
torch - heat 'em up really good then unbolt. heat should loosen them right up
Old Aug 2, 2004 | 08:30 AM
bodiez's Avatar
Hit the floor!
Default Re: What is the best way to break the exhaust free? (notoriousB)
Long pipe on the end of a wrench works all the time
Old Aug 2, 2004 | 09:25 AM
pyrojeff's Avatar
Default Re: What is the best way to break the exhaust free? (bodiez)
Screw that, PB Blaster owns all.
Spray it good, bang on the bolt with a wrench, and spray it again, and let it sit overnight. It WILL come loose.
Old Aug 2, 2004 | 10:52 AM
Steed77's Avatar
Default Re: What is the best way to break the exhaust free? (pyrojeff)
I would also try PB Blaster along with some air tools. Should not be to bad.
Old Aug 2, 2004 | 11:51 AM
93accordsleeper's Avatar
heat nut up slightly red it will swell for easy removal. dont heat bolt only nut
grg3135
Apr 14, 2008 07:13 PM
LaOstha
Sep 1, 2006 02:32 PM
drifter_for_life06
Jun 30, 2005 06:12 AM
95GSRTT
May 1, 2005 07:14 AM
94TealGSR
Jan 16, 2003 09:14 PM
