ticking sound when turning
cv joint, look and see if your boot is cracked, if you need help on any of your parts come down to Culpeper and I will give you a hand!HeHe
Yeah, I vote for the axle too. When my hatch had a torn boot, same symptoms - only under throttle while turning. It also lessened or disappeared after a few turns (although it was still noticable - even after the joint was repacked and the boots replaced).
I've also got $5 on a certain shop incorrectly installing your axles or boots leading to this perdicament. I think I would bitch at them a bit before I went out of pocket for a fix.
Good point, mang. Yeah the axels they installed have a lifetime warrentee and these suckers are only 3 months old. That's pretty disturbing. Dern hybrids...
cv joints. don't let the ticking get to the point where it's evident in a straight line. easy as **** to replace the whole axle, though. did it about 6 months ago, cake.
riceforlife
Suspension & Brakes
13
Dec 12, 2007 11:27 PM
JDM R
12
Aug 27, 2004 04:15 PM
