Camber spec..
Old Nov 28, 2001 | 09:18 AM
IntegraGSR23's Avatar
Default Camber spec..
I was wonder if rim sizes have any effect when getting an alignment done? Will it have any effects on the camber spec? I will be dropping my car soon (1.25') and was curios because I have 17" rims
Old Nov 28, 2001 | 12:16 PM
Default Re: Camber spec.. (IntegraGSR23)
Anyone?
Old Nov 28, 2001 | 12:41 PM
dynamite C1's Avatar
I have a 205/40/17 and they did aligned it. Rule of thumb is to have your wheels aligned after lowering and or changing your tire size. After aligning your wheels, ask the shop to hand u the print out of the wheel alignment. You will see or ask them if the camber is off, they usually give the print out anyway.
Old Nov 28, 2001 | 01:53 PM
Default Re: Camber spec.. (dynamite C1)
I have the same spec tires. I am aware that you should get an alignment done after dropping your car. My question is do the larger rims have any effect on the camber spec or no? would the spec be the same regardless the size?
95accordian
Mar 8, 2014 01:31 PM
killercrx91
Mar 16, 2009 04:23 AM
JdmB16Eg6
Suspension & Brakes
Mar 28, 2006 10:29 AM
The Poopsmith
Mar 17, 2003 02:40 PM
kikkoboyie
Sep 17, 2001 04:26 AM
