all motor h22...
Old Aug 1, 2004 | 11:28 PM
b16t4turbo's Avatar
Default all motor h22...
i have a 94 jdm close deck h22 with crower valve train, skunk2 sprockets, type s cams, standard stainless steel valves (dished), bottom end is stock, m2b4 lsd tranny, stock lighten flywheel, heavy duty act pp with 6 puck, intake manifold with butterflys removed, chipped p28 with mugen specs (vtec at 5000, redline at 8500). all this is in a 93 civic coupe.
The question is what can i do to improve my quarter mile time (best 12.9 @ 103mph). should i adjust my sprockets, if so what is the best adjust? should i make my vtec engage sooner or later, if so what is the best engagment?
thanks.
Old Aug 2, 2004 | 08:21 AM
Pat McGroin's Avatar
Default Re: all motor h22... (b16t4turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16t4turbo &raquo;</TD></TR><TR><TD CLASS="quote">i have a 94 jdm close deck h22 with crower valve train, skunk2 sprockets, type s cams, standard stainless steel valves (dished), bottom end is stock, m2b4 lsd tranny, stock lighten flywheel, heavy duty act pp with 6 puck, intake manifold with butterflys removed, chipped p28 with mugen specs (vtec at 5000, redline at 8500). all this is in a 93 civic coupe.
thanks. </TD></TR></TABLE>Damn 12.9 @ 103!?!?!?!? Please tell me more info with that timeslip I am curious!
With Newman's p28 I believe
vtec x-over is at 4800-4900. Only way to find out for sure where to lower your vtec x-over is to put your car on a dyno and take a look at the plot.
Have you upgraded the header or intake? You could also try hondata's or some other company's intake manifold gasket kit (extra hp for cheap).
Also I am not too sure on this but could the Crower valvetrain be a little too much for type S cams?
Old Aug 2, 2004 | 12:49 PM
b16t4turbo's Avatar
Default Re: all motor h22... (Pat McGroin)
well my coupe has no back seats, heater core, no ac system, ect. just the motor in the shell. it was running on open headers on 13x24.5x8.5 slicks. i got the crower vavle train because i was planning to see what i can do with the type s cams first then hit up some higher lift cams later. i also have i,h,e. forgot to mention it.
thanks for the info.
eg_h22
106
Jun 25, 2007 10:52 AM
2.2SICKLUDE
Sep 25, 2003 10:44 PM
Benson
Feb 6, 2003 06:46 AM
