Swap starts in 3 days, and I keep finding crap missing or messed up
Old Aug 1, 2004 | 11:05 PM
BlueShadow's Avatar
Default Swap starts in 3 days, and I keep finding crap missing or messed up
Hi guys,
So anyways, I'm supposed to start my swap on the 4th, and I am here dissassembling the motor for transport. I keep finding crap missing here and there...yesterday my throwout bearing spring was bad, today it was my alternator which had a different socket. But now I see that my TB is missing the small metal pipe above the TB.
I was just wondering what would happen if I run the car without a line running from that small metal pipe which is supposed to be connected to the EVAP canister. I'll probably have to do this for a few days until I can fix the problem.
TIA
Old Aug 1, 2004 | 11:31 PM
nikitad's Avatar
Default Re: Swap starts in 3 days, and I keep finding crap missing or messed up (BlueShadow)
Nothing bad will happen. in the case you do get a significant vacuum leak through there, just plug it with some playdoh. Or quicksteel, if you want it plugged permanently.
Although for cali smog, I assume, you'd want it to be connected to the evap, sooner or later.
Old Aug 1, 2004 | 11:38 PM
BlueShadow's Avatar
Default Re: Swap starts in 3 days, and I keep finding crap missing or messed up (nikitad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nikitad &raquo;</TD></TR><TR><TD CLASS="quote">Nothing bad will happen. in the case you do get a significant vacuum leak through there, just plug it with some playdoh. Or quicksteel, if you want it plugged permanently.
Although for cali smog, I assume, you'd want it to be connected to the evap, sooner or later.</TD></TR></TABLE>
It's on the intake side of the throttle plate, so I'm assuming that it's not a vacuum source but an atmospheric source. I did manage to get my old B16a TB and cut off the pipe on the TB. I could put that on the tip of my vacuum line and use a little super glue and some zip ties to make sure it stays on the TB. That should hold me over until I can get a large diameter BBK or other aftermarket TB.
ERKK
Sep 9, 2008 11:53 PM
atlplayer4life90
May 31, 2008 06:26 AM
SL0-hatch
Apr 25, 2007 10:27 PM
doodooheadfart
81
Jun 6, 2006 10:53 AM
Skeletor
85
Jun 29, 2004 09:56 AM
