help needed!!! screeching noise....not sounding too good...pleasssseeee.....
Old Aug 1, 2004 | 10:33 PM
DA KING's Avatar
Default help needed!!! screeching noise....not sounding too good...pleasssseeee.....
well i have a 2nd gen integ. just recently, it started to make a somewhat screeching sound, especially when im backing up to parallel park. like if i steer the wheel to the right or left, it would make a distinct noise, kinda like a screeching noise. anyone got an idea on how to solve this or even know what the problem can be...?? any help is well appreciated. thanks a lot h-t!!!
Old Aug 1, 2004 | 11:00 PM
DA KING's Avatar
Default Re: help needed!!! screeching noise....not sounding too good...pleasssseeee..... (DA KING)
HELP!HELP!HELP!HELP!HELP!HELP!HELP!HELP!HELP!HELP! HELP!HELP!
Old Aug 2, 2004 | 12:21 AM
DA KING's Avatar
damn...anyone?
Old Aug 2, 2004 | 06:03 AM
SpyderZEX's Avatar
Do you have power steering? You said that it only happens when you turn the wheel, correct?
Old Aug 2, 2004 | 07:14 AM
lildevock's Avatar
Do you have stock wheels and tires? It if is only when you are turning that means your tires could be rubbing. That would only be a problem is you have bigger wheels and tires then stock.
Old Aug 2, 2004 | 07:31 AM
JimBlake's Avatar
Default Re: help needed!!! screeching noise....not sounding too good...pleasssseeee..... (lildevock)
Worn brake pads?
Old Aug 2, 2004 | 07:50 AM
95db8GSR's Avatar
probably your power-steering belt slipping...if the belt is a little stretched or never had the proper tension to begin with, they slip, especially when you turn the wheel all the way to one side...try tightening the tensioner on the PS belt and let us know how it turns out.
Old Aug 2, 2004 | 08:00 AM
nintylsteg's Avatar
like stated ither powersteering but on mine when i reverse my rear brakemakes a skeeking noise that is kinda loud just my input
Old Aug 2, 2004 | 10:58 AM
DA KING's Avatar
thanks to everyone that replied. i really appreciated it. its becoming a problem. if anyone has anymore input, please feel free to post. TIA!
PaPa_No~No
Oct 29, 2011 08:12 PM
Harlowe
Honda Civic (2001 - 2005)
11
May 29, 2008 04:48 PM
m0dr0cker
18
Oct 6, 2003 06:58 AM
816d16
May 16, 2003 03:50 PM
padraf
Mar 21, 2002 05:26 AM
