msd coil help
Old Aug 1, 2004 | 10:20 PM
asnboi_512's Avatar
Default msd coil help
anyone know how to just use the msd coil with out the msd box? i just wanna use stock wiring to the coil but which wires go to which side? i have 3 wires that went to the stock coil... and this msd coil has a possy side and a neggy side i have two yellow wires.. one with a black stripe and the other wire is green.. anyone know where they go?
Old Aug 1, 2004 | 11:02 PM
asnboi_512's Avatar
Default Re: msd coil help (asnboi_512)
bump
Old Aug 2, 2004 | 12:30 AM
accordium's Avatar
i'm not sure what color your 3 wires are from your wording, i'm guessing yellow, yellow/black, and green? Are you sure yellow/black isn't really yellow/green? if so, green goes to the coil negative, yellow goes to coil positive, and yellow/green is hooked up to the ignition control module (ICM).
Old Aug 2, 2004 | 12:28 PM
asnboi_512's Avatar
Default Re: msd coil help (accordium)
well see.. theres are 3 wires.. one solid green.. one black with yellow stripe.. and one solid yellow.. the black with yellow stripe and the solid yellow one are pretty thick. the green one is alot thinner than the rest i still cant figure this out
kornkid21792
Aug 21, 2010 11:25 PM
niterider96cord
Feb 3, 2010 05:04 PM
RACING INTEGRATION
Oct 4, 2005 11:05 PM
B_1_8_hatch
Nov 28, 2003 08:28 PM
slow02ss camaro
Nov 7, 2003 02:44 PM
