What parts of a 94+ Teg will fit 94 civic coupe?
Old Aug 1, 2004 | 09:17 PM
MulletManRockStar's Avatar
Default What parts of a 94+ Teg will fit 94 civic coupe?
My main question is if I got say a wrecked 94 ls with 5 speed could I use the clutch pedal,linkage and all the hydro stuff to convert my civic coupe to a manual from auto or will I have to get the manual swap stuff from a civic? Also which year tegs are obd 1? Thanks
Old Aug 1, 2004 | 09:23 PM
ej1 pilot's Avatar
Default Re: What parts of a 94+ Teg will fit 94 civic coupe? (MulletManRockStar)
no a 1.8L clutch wont go in a civic
ej1 pilot's Avatar
Default Re: What parts of a 94+ Teg will fit 94 civic coupe? (Art In Motion)
its mostly just interior and some exterior parts that are interchangeable
Old Aug 1, 2004 | 09:50 PM
hatchi's Avatar
you can transfer basically whole motor setup, suspension, interior (dash needs some modifying) seats will bolt up (only fronts) and lower cushoin part
Old Aug 2, 2004 | 09:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art In Motion &raquo;</TD></TR><TR><TD CLASS="quote">no a 1.8L clutch wont go in a civic</TD></TR></TABLE>
so if i swaped the b18 from the ls with the 5 speed I cant take the clutch assemble,pedals,hyrdo master cyclinder deal, and linkage as well? I wouldnt want to buy a civic parts car and a integra parts car if all I need is the teg. again heres what I would like to swap from the a teg
1.b18 2.trans 3. clutch pedals,hydro deal,linkage 4.front seats and backs if they swap(in a coupe)..thanks for the replys so far
Old Aug 2, 2004 | 09:50 PM
Default Re: What parts of a 94+ Teg will fit 94 civic coupe? (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">you can transfer basically whole motor setup, suspension, interior (dash needs some modifying) seats will bolt up (only fronts) and lower cushoin part</TD></TR></TABLE>
oops my fault i didnt read this....is the lower cusion part just the front seats lower or rear seat lower dont fit? sorry if its dumbs question.
Old Aug 2, 2004 | 09:57 PM
2fast4u831's Avatar
I'm really 2slow
engine,tranny,pedals,linkage,clutch lines,master cylinder,slave cylinder seats will bolt into your civic. The only concern are the rear seats. obd-1 tegs are 94 and 95.
Old Aug 3, 2004 | 01:18 PM
Default Re: (2FAST4U831)
awesome...thanks man
94_cd5
Transmission & Drivetrain
Oct 21, 2017 11:31 AM
dadsvtechonda
May 24, 2007 04:11 PM
memorybox
Jan 7, 2007 04:03 PM
